BT.com
Wishlist
Euroscreen Connect Electric VA 230cm x 129.5cm Matt White -
Euroscreen Connect Electric VA...
£413.85
Hurry, only 1 left in stock!
£413.85
Add to wishlist
Delivery
Standard 1-3 working days
Connect Electric is a basic compact screen which is very easy to install. It can be mounted either on the wall or in the ceiling and is attached to the wall/ceiling with one screw at each end of the case. The screen can be operated by an in-line switch, an IR remote control or automatically by an AutoLink connected to the projector.
Euroscreen Connect Electric Wide Format - projection screen - 104 in (264 cm)
Projection screen - motorised
Placing / Mounting
Ceiling mountable, wall mountable
White
Projection Screen Image Diagonal Size
104 in (264 cm)
Projection Image Size
230 cm x 130 cm
Aspect Ratio
16:9
Screen Surface
Arctiq
Product Material
Fibreglass
249 cm x 7.5 cm x 7.5 cm
United Kingdom
2 years warranty
Placing / Mounting
Image Diagonal Size
104 in (264 cm)
Image Width
230 cm
Image Height
130 cm
Screen Surface
Arctiq
Aspect Ratio
16:9
Gain
1.0x
Viewing Angle
180°
Screen Thickness
0.37 mm
Mildew resistant, washable, black backing, flame retardant
Product Material
Fibreglass
249 cm - 7.5 cm - 7.5 cm
White
United Kingdom
Dust resistant
Plug and Play, REACH, GREENGUARD
Scroll to top
