BT.com
Wishlist
Euroscreen Connect Electric 200cm x 200cm Matt White
Euroscreen Connect Electric 200cm x...
£389.62
£389.62
Add to wishlist
Delivery
Standard Due date unavailable
Connect Electric is a basic compact screen which is very easy to install. The case is made of steel and painted white. It can be mounted either on the wall or in the ceiling and is attached to the wall/ceiling with one screw at each end of the case. The screen can be operated by an in-line switch, an IR remote control or automatically by an AutoLink connected to the projector. For system installations it's also avalible with cable only. All control options are easily connected to the screen via the universal connector on the screens left side.
The screen fabric has a matt white surface which provides a 180ยบ viewing angle.
Scroll to top
