BT.com
Wishlist
Euroscreen 77" Manual 16:9 Screen
£150.00
Hurry, only 2 left in stock!
£150.00
Add to wishlist
Delivery
Standard 1-3 working days
Connect is a basic compact screen which is very easy to install. The case is made of steel. It can be mounted either on the wall or in the ceiling and is attached to the wall/ceiling with one screw at each end of the case.
Euroscreen Connect Wide Format - projection screen
Projection screen
Placing / Mounting
Ceiling mountable, wall mountable
Projection Image Size
170 cm x 95 cm
Aspect Ratio
16:9
Screen Surface
Matte White
189 cm 165 cm
7.3 kg
Projection screen
Placing / Mounting
Image Width
170 cm
Image Height
95 cm
Screen Surface
Matte White
Aspect Ratio
16:9
Viewing Angle
180°
189 cm 165 cm
7.3 kg
Scroll to top
