BT.com
Wishlist
Euroscreen 113" Manual projector screen
Euroscreen 113" Manual projector...
£249.34
£249.34
Add to wishlist
Delivery
Standard Due date unavailable
Connect is a basic compact screen which is very easy to install. The case is made of steel and painted white. It can be mounted either on the wall or in the ceiling and is attached to the wall/ceiling with one screw at each end of the case. The screen is operated manually.
Draper Connect Video Format - projection screen - 113 in (288 cm)
Projection screen
Placing / Mounting
Ceiling mountable, wall mountable
White
Projection Screen Image Diagonal Size
113 in (288 cm)
Projection Image Size
230 cm x 173 cm
Aspect Ratio
4:3
Screen Surface
Arctiq
249 cm
10.3 kg
Projection screen
Placing / Mounting
Image Diagonal Size
113 in (288 cm)
Image Width
230 cm
Image Height
173 cm
Screen Surface
Arctiq
Aspect Ratio
4:3
Gain
1.0x
Viewing Angle
180°
Screen Thickness
0.37 mm
Border Size
5 cm
Mildew resistant, washable, black backing, black borders, flame retardant
249 cm
10.3 kg
White
Dust resistant
Scroll to top
