BT.com
Wishlist
Ergotron StyleView Sit-Stand Combo Arm Mounting Kit
Ergotron StyleView Sit-Stand Combo...
£524.10
£524.10
Add to wishlist
Delivery
Standard Due date unavailable
Durable aluminum construction! It holds a monitor, bar-code scanner, keyboard, wrist rest and mouse on the same arm, providing easy, single-motion height adjustment. Work sitting or standing with the arm's ergonomic 25" LCD height adjustment range. A unique cable management system conceals and organizes cords, making cleaning easy.
Ergotron StyleView Sit-Stand Combo Arm - wall mount
Wall mount
Tilt
+25° to -5°
Pan
360°
Lift
63 cm
Rotation
360°
11.2 kg
Recommended Use
LCD display / keyboard / mouse / bar code scanner
Recommended Display Size
Up to 24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
13.2 kg
Material
Aluminium, high-grade plastic
White
5 years warranty
11.2 kg
Material
White
AV Furniture
Wall mount
Mounting Components
Mouse holder, wall track mount, wrist rest, barcode scanner holder, VESA adapter, wall mount bracket, 4 hole pattern expansion adapters, keyboard tray
Recommended Use
Cable Management
Integrated cable management
Up to 24"
Tilt
+25° to -5°
Pan
360°
Lift
63 cm
Rotation
360°
Adjustments
Max Load Weight
13.2 kg
Dimensions & Weight Details
Dimensions
Keyboard tray - width: 47.2 cm, depth: 22.8 cm
Limited warranty - 5 years
Scroll to top
