BT.com
Wishlist
Ergotron Side by Side Mount
£250.84
41 in stock
£250.84
Add to wishlist
Delivery
Standard 1-3 working days
Durable polished aluminum construction! Create a fully adjustable side-by-side configuration that lifts both LCD screens up to where they're easier to see while reclaiming valuable worksurface.
Reposition your LCDs with just a touch. Up. Down. Forward. Back. The LX provides unparalleled range of motion. Save time by using multiple applications at once - eliminate toggling back and forth between documents and programs.
Ergotron LX Dual Side-by-Side Arm - mounting kit
Mounting kit - desktop stand
Mounting Components
Desk clamp mount, grommet mount, 2 articulating arms, 2 extension brackets
Tilt
Recommended Use
LCD display
Recommended Display Size
Up to 27"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
18.1 kg
5 years warranty
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Desktop stand
Up to 27"
Tilt
Max Load Weight
18.1 kg
Rotating, portrait to landscape movement
Limited warranty - 5 years
Scroll to top
