BT.com
Wishlist
Ergotron Neo-Flex Dual LCD Lift Stand 24" Monitor
Ergotron Neo-Flex Dual LCD Lift...
£130.03
More than 50 in stock
£130.03
Add to wishlist
Delivery
Standard 1-3 working days
Affordable, height-adjustable dual-monitor stand for maximum productivity and comfort. Save time by using multiple applications at once - eliminate toggling back and forth between documents and programs. Simultaneously lift LCD screens to proper height for unsurpassed ergonomic comfort.
Ergotron Neo-Flex Dual LCD Lift Stand - stand
Stand
Pan
360°
7.2 kg
Recommended Use
2 LCD displays
Recommended Display Size
Up to 24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
15.4 kg
3 years warranty
7.2 kg
AV Furniture
Stand
Recommended Use
2 LCD displays
Up to 24"
Pan
360°
Max Load Weight
15.4 kg
Adjustable height, rotating
Limited warranty - 3 years
Scroll to top
