BT.com
Wishlist
Ergotron LX Sit-Stand Wall Mount LCD Arm
Ergotron LX Sit-Stand Wall Mount...
£165.36
Hurry, only 3 left in stock!
£165.36
Add to wishlist
Delivery
Standard 1-3 working days
This versatile arm can be used in a variety of applications: attach a smaller monitor for use within a sit-stand workstation or add a large display up to 11.3 kg to position digital signage.
The LX provides unparalleled range of motion, being able to accommodate a user's sitting or standing posture - features 20 inches of vertical adjustment and 62 inches of side-to-side adjustment.
Ergotron LX Sit-Stand Wall Mount LCD Arm - mounting kit
Mounting kit - wall-mountable
Mounting Components
Wall arm, mounting base, VESA adapter, extension arm bracket
Tilt
Pan
5 kg
Recommended Use
LCD display
Recommended Display Size
42"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
11.3 kg
Material
Aluminium
Polished aluminium
5 years warranty
5 kg
Material
Aluminium
Polished aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
42"
Tilt
Pan
Max Load Weight
11.3 kg
Horizontal or vertical screen orientation, rotating
Limited warranty - 5 years
Scroll to top
