BT.com
Wishlist
Ergotron DeskStand DS100 Stand
£246.73
15 in stock
£246.73
Add to wishlist
Delivery
Standard 1-3 working days
The DS100 Series is a line of products within Ergotron's flat panel monitor Adjustable Rotating Mounting Solutions (ARMS). Conserve desk space by suspending flat panel monitors on a single base. Choose between multiple configurations and adjustment ranges. Easily adjust the height and position of all monitors to a comfortable, ergonomically appropriate position. Patented pivot mechanisms allow you to tilt, pivot and turn your flat panel monitors for maximum efficiency and ergonomic comfort. Free Standing, Desk Clamp, and Grommet Mount Bases are available for all configurations. This Free Standing Base Vertical Double Monitor configuration manages from 15" to 20" flat panel monitors and up to 23 lbs.
Ergotron DeskStand DS100 - stand
Stand
Tilt
Pan
Recommended Use
2 LCD displays
Recommended Display Size
Up to 27"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
20.9 kg
Material
Aluminium, steel
5 years warranty
Material
Aluminium, steel
AV Furniture
Stand
Recommended Use
2 LCD displays
Up to 27"
Tilt
Pan
Max Load Weight
20.9 kg
Rotating
Limited warranty - 5 years
Scroll to top
