BT.com
Wishlist
Ergotron AIO Stand
Ergotron AIO Stand
£82.24
Ergotron AIO Stand
Ergotron AIO Stand
£82.24
Add to wishlist
Delivery
Standard Due date unavailable
A robust hinge mechanism provides an incredible 115 degrees of tilt adjustment while simultaneously controlling monitor height. This flexibility allows the screen to be moved parallel with the desktop - perfect for touchscreen applications.
This stand's strength and heavy-duty design also make it well suited for use with all-in-one PCs and hefty displays.
Ergotron Neo-Flex Touchscreen Stand - stand
Stand
Tilt
Pan
Recommended Use
Touch screen
Recommended Display Size
Up to 27"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10.8 kg
3 years warranty
AV Furniture
Stand
Recommended Use
Touch screen
Up to 27"
Tilt
Pan
Max Load Weight
10.8 kg
Adjustable height
Limited warranty - 3 years
Scroll to top
