BT.com
Wishlist
Ergotron 45-266-026 StyleView Sit-Stand Combo Arm
Ergotron 45-266-026 StyleView...
£527.91
£527.91
Add to wishlist
Delivery
Standard Due date unavailable
Durable polished aluminum construction! Holds a monitor, bar-code scanner, keyboard, wrist rest and mouse on the same arm, providing easy, single-motion height adjustment. Work sitting or standing with the arm's ergonomic 25" (64 cm) LCD height adjustment range. A unique cable management system conceals and organizes cords, making cleaning easy.
Ergotron StyleView Sit-Stand Combo Arm - mounting kit (Lift and Pivot)
Mounting kit (Lift and Pivot)
Mounting Components
Articulating arm, wall track mount
Integrated Devices
Flat panel lift
Adjustable Height
0-64 cm
Tilt
Recommended Use
LCD display / keyboard / mouse / bar code scanner
Recommended Display Size
Up to 24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
13.2 kg
Material
Plastic, aluminium
5 years warranty
Adjustable Height
0-64 cm
Material
Plastic, aluminium
AV Furniture
Mounting kit
Mounting Components
Design
Lift and Pivot
Recommended Use
Integrated Devices
Flat panel lift
Up to 24"
Tilt
Max Load Weight
13.2 kg
Adjustable height, portrait to landscape movement
Limited warranty - 5 years
Scroll to top
