BT.com
Wishlist
Ergotron 45-234-200 200 Series Wall Mount Arm
Ergotron 45-234-200 200 Series Wall...
£166.71
£166.71
Add to wishlist
Delivery
Standard 1-3 working days
Extend or retract, swing, tilt or turn your flat panel monitor for maximum efficiency and ergonomic comfort. The 200 series' slim profile saves space, yet moves your screen to where you need it most.
Ergotron 200 Series Wall Mount Arm - wall mount
Wall mount
Tilt
Recommended Use
LCD display
Recommended Display Size
Up to 24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Material
Steel
5 years warranty
Material
Steel
AV Furniture
Wall mount
Mounting Components
Wall bracket, pivot wall mount, 2 extension brackets
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
Up to 24"
Tilt
Max Load Weight
11.3 kg
Rotating, portrait to landscape movement
Limited warranty - 5 years
Scroll to top
