BT.com
Wishlist
ErgoMounts LX DESK MOUNT LCD ARM
£122.19
More than 50 in stock
£122.19
Add to wishlist
Delivery
Standard 1-3 working days
Durable polished aluminum construction! Sleek and streamlined, the LX frees up space and allows positioning of your display for greater productivity. Reposition your LCD with just a touch. The LX provides unparalleled range of motion.
Ergotron LX Desk Mount LCD Arm - mounting kit
Mounting kit
Mounting Components
Articulating arm, desk clamp mount, grommet mount, extension brackets
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
3.6 kg
Recommended Use
LCD display
Recommended Display Size
Up to 32"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Material
Aluminium
Polished aluminium
10 years warranty
3.6 kg
Material
Aluminium
Polished aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Up to 32"
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Max Load Weight
11.3 kg
Min Load Weight
2.3 kg
Horizontal or vertical screen orientation, adjustable height, rotating
Limited warranty - 10 years
Scroll to top
