BT.com
Wishlist
ErgoMounts Ergotron WM Low Profile Wall Mount - mounting kit
ErgoMounts Ergotron WM Low Profile...
£78.51
7 in stock
£78.51
Add to wishlist
Delivery
Standard 3-5 working days
The WM's wall-hugging design hangs your large flat panel display just over an inch from the wall for an extremely slim profile. Yet this TV wall mount costs about half that of competing models. Engineered to install in three easy steps, the WM is sturdy and stable.
Mounting kit - wall-mountable
Mounting Components
Wall plate, fasteners, 2 brackets
84.5 cm x 5.5 cm x 26 cm
Tilt
4.5 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
From 32"
Max Mounting Pattern Size
600 x 450 mm
Max Load Weight
79 kg
Mounting Stud Centers
16"
Material
Aluminium, steel
Silver
5 years warranty
84.5 cm
5.5 cm
26 cm
4.5 kg
Material
Aluminium, steel
Silver
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
Placing / Mounting
Wall-mountable
600 x 450 mm
16"
From 32"
Tilt
Max Load Weight
79 kg
Limited warranty - 5 years
Scroll to top
