BT.com
Wishlist
ErgoMounts Ergotron Neo-Flex Widescreen Lift Stand - stand
ErgoMounts Ergotron Neo-Flex...
£125.59
£125.59
Add to wishlist
Delivery
Standard 1-3 working days
Upgrade your widescreen display with five-inch (12.7 cm) height adjustment, tilt, pan and portrait-to-landscape rotation for optimum viewing. Embedded with patented motion technology, this stand enables light-touch adjustments without any knobs or levers.
Stand
Tilt
Pan
Recommended Use
LCD display
Recommended Display Size
20"-32"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
16.3 kg
3 years warranty
AV Furniture
Stand
Recommended Use
LCD display
20"-32"
Tilt
Pan
Max Load Weight
16.3 kg
Min Load Weight
7.3 kg
Adjustable height, rotating
Limited warranty - 3 years
Scroll to top
