BT.com
Wishlist
Epson WORKFORCE WF-7515
Delivery
Standard Due date unavailable
Time-saving features: Prints are delivered quickly and efficiently at up to 34 pages per minute in draft mode, and up to 15 mono and 8.4 colour pages per minute for business-quality documents.
Productive: High-capacity 250-sheet paper tray for less frequent refilling and a 30-sheet Automatic Document Feeder for multiple page scanning, copying and faxing at up to A3.
Economical: See savings of up to 50 percent on cost per page compared to competitive lasers. Businesses can also print up to 1,000 pages, equivalent to two reams of paper, with Epson's individual XL Stag inks. ENERGY STAR-qualified reduced power consumption further cuts costs and environmental impact. Up to 80% lower energy consumption than competitive colour lasers and more affordable than the laser equivalent.
Get connected: Share across the entire business with Ethernet or Wi-Fi connectivity with enhanced WPA2 wireless security. The WF-7515 also comes with Epson Connect which offers even more flexibility and freedom, allowing users to quickly and easily print images and documents wirelessly from smartphones and tablet PCs. Additionally, users can print from anywhere in the world by emailing documents and images directly to the printer. Google Cloud Print is also supported.
Furthermore, the WF-7515 is AirPrint Ready which enables users to print emails, photos, web pages and documents directly from an iPad, iPhone and iPod Touch.
Easy to use: A 6.3cm colour LCD screen with accompanying PictBridge, USB flash and memory card slots offer straightforward PC-free printing.
Epson WorkForce WF-7515 - multifunction printer (colour)
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 34 ppm (mono) / up to 34 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 200 dpi, 200 x 100 dpi
Scanning
1200 x 1200 dpi
Original Size
A3 (297 x 420 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
A3 plus (311 x 457 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
250 sheets
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
AC 230 V
55.9 cm x 41.8 cm x 28.7 cm
15.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
PC Connection
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
384 nozzles (black), 3 x 128 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
2 pl
Ink Type
Epson DURABrite Ultra inks
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 180 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
60 station(s)
Broadcast Transmission
Yes (black only)
Colour faxing, group dialling, delayed sending
Document & Media Handling
Max Original Size
A3 (297 x 420 mm)
Original Type
Sheets
30 sheets
Max Media Size
A3
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
250 sheets
Input tray - 250 sheets , ADF - 30 sheets
Speed Details
Printing: up to 34 ppm (A4) - B/W , Printing: up to 34 ppm (A4) - colour , Printing: up to 15 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 8.4 ppm (A4) - color (ISO/IEC 24734)
1 x USB 2.0 , 1 x USB host , 1 x LAN
Security Protocols & Features
WEP, WPA-PSK, WPA2, TKIP, AES
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.4.11 or later, MS Windows Server 2008, MS Windows Server 2008 R2
Software Included
Epson Event Manager, Epson Easy Photo Print, Epson Fax Utility, Presto! PageManager 9
AC 230 V
20 Watt
Power Consumption Sleep
4.2 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
Limited warranty - 1 year
55.9 cm
41.8 cm
28.7 cm
15.6 kg
Accessories
Epson Matte Paper Heavyweight A4 50 sheets
Quicklinx: N6V | In Stock
£11.14
Scroll to top
