BT.com
Wishlist
Epson WORKFORCE WF-7015
Delivery
Standard Due date unavailable
Engineered for business: Print high-quality colour documents at up to A3+ size as well as double-sided A4 documents.
High-speed: Prints are delivered quickly and efficiently with speeds of up to 34 pages per minute in draft mode, and up to 15 mono and 8.2 colour pages per minute for business-quality documents.
Productive: It has twin high-capacity 250-sheet paper trays for less frequent refilling. This also means you can keep it stocked with both A3 and A4 paper which helps save time and gives you media flexibility.
Share securely: Ethernet and Wi-Fi connectivity come as standard, featuring enhanced wireless security with WPA2 encryption.
Economical: See savings of up to 50 percent on cost per page compared to competitive lasers. Print up to 1,000 pages, equivalent to two reams of paper, with Epson's individual XL Stag inks, while double-sided printing can save paper usage and costs by up to 50 percent. ENERGY STAR-qualified reduced power consumption further cuts costs and environmental impact. Up to 80% lower energy consumption than competitive colour lasers.
Epson WorkForce WF-7015 - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
12.3 kg
Inkjet Technology
Epson Micro Piezo
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
Legal
Max Media Size
Legal (216 x 356 mm), A3 plus (329 x 423 mm)
Print Speed
Up to 34 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ppm - colour - A4 (210 x 297 mm) , Up to 15 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 8.2 ppm - color (ISO/IEC 24734) - A4 (210 x 297 mm)
Max Resolution (B&W)
5760 x 1440 dpi
Max Resolution (Colour)
5760 x 1440 dpi
Automatic Duplexing
USB, LAN, Wi-Fi(n)
Media Type
Envelopes, plain paper
Total Media Capacity
500 sheets
Media Handling
2x 250-sheet input trays
Print server - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
AC 230V
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X 10.4.11 or later
Microsoft Certification
Compatible with Windows 7
1 year warranty
55.8 cm x 41.4 cm x 26.4 cm
Printer Type
Printer
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
384 nozzles (black), 3 x 128 nozzles (cyan, magenta, yellow)
Minimum Ink Droplet Size
2 pl
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Type
Epson DURABrite Ultra inks
Print Speed
Wireless
USB, LAN, Wi-Fi(n)
5760 x 1440 dpi
5760 x 1440 dpi
Automatic Duplexing
Media Handling
Media Handling
Media Type
Media Size Class
Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
500 sheets
Media Feeders
2 x automatic - 250 sheets
Print server
Security Protocols & Features
WEP, WPA-PSK, WPA2
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Power supply - internal
AC 230V
20 Watt
Power Consumption Stand by / Sleep
3.7 Watt
Software Included
EPSON Easy Photo Print
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
55.8 cm
41.4 cm
26.4 cm
12.3 kg
Accessories
Epson Matte Paper Heavyweight A4 50 sheets
Quicklinx: N6V | In Stock
£10.93
Scroll to top
