BT.com
Wishlist
Epson WorkForce WF-3620DWF Colour Inkjet Multifunction Printer
Delivery
Standard Due date unavailable
A4 duplex 4-in-1
This model comes with a 35-sheet automatic document feeder and offers duplex print, scan, copy and fax functions. In addition to the front loading paper tray, the rear speciality paper path means you can print on a wide range of thicker paper, envelopes or labels to suit your business needs.
Mobile printing
Epson Connect allows you to print important office documents from smartphones and tablets. You can also print from anywhere in the world by emailing files directly to the printer, and store scanned documents in cloud services. In addition, this printer is also Google Cloud Print and Apple AirPrint compatible. For added versatility, Wi-Fi Direct allows easy printing from wireless devices without having to connect to a wireless router.
New printhead
PrecisionCore, Epson's most advanced printhead technology, powers the industry-leading output quality and durability that Epson is renowned for, at the high speeds required for office, commercial and industrial printing.
Durable ink
Epson's DURABrite Ultra Ink is ideal for producing laser-like business documents. Documents are water, smudge and highlighter resistant, while its quick-drying properties make it perfect for duplex printing. Available in 27XXL, 27XL and standard sizes, these high-capacity, individual ink cartridges offer great savings, with a 50% lower cost-per-page than competitive lasers4.
Epson WorkForce WF-3620DWF - multifunction printer (colour)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
20000 pages
Max Printing Speed
Up to 19 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 4800 x 2400 dpi (mono) / up to 4800 x 2400 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Output Trays Capacity
125 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Google Cloud Print ready, scan to Cloud
AC 230 V
44.9 cm x 41.7 cm x 24.3 cm
9.7 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
20000 pages
Display Features
Touch screen
PC Connection
AirPrint Enabled
Supported Flash Memory
SD Memory Card, USB flash drive, SDHC Memory Card, SDXC Memory Card
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
800 nozzles (black), 3 x 256 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
2.8 pl
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 180 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
100 station(s)
Automatic redialing, colour faxing
Document & Media Handling
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
250 sheets
Max Media Capacity
250 sheets
125 sheets
Input tray - 250 sheets , ADF - 35 sheets , Output tray - 125 sheets
Speed Details
Printing: up to 19 ppm - B/W (ISO/IEC 24734) , Printing: up to 10 ppm - color (ISO/IEC 24734) , Printing: up to 9.2 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 6.3 ppm (A4) - colour duplex (ISO/IEC 24734)
1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, TKIP, AES, Wi-Fi Direct
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2003 R2, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition
Software Included
Drivers & Utilities
AC 230 V
17 Watt
Power Consumption Standby
7.3 Watt
Power Consumption Sleep
1.6 Watt
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
ENERGY STAR Certified
Limited warranty - 1 year - carry-in
44.9 cm
41.7 cm
24.3 cm
9.7 kg
Shipping Width
52.5 cm
Shipping Depth
48.5 cm
Shipping Height
32.7 cm
Shipping Weight
11.85 kg
Accessories
Ink
£15.67
£11.24
Epson Matte Paper Heavyweight A4 50 sheets
Quicklinx: N6V | In Stock
£11.07
£14.24
Other bundles
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.62
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£19.63
£13.69
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.54
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£17.96
Scroll to top
