BT.com
Wishlist
Epson WorkForce WF-2510WF Colour Inkjet Multifunction Printer
Epson WorkForce WF-2510WF Colour...
£59.43
Print Wirelessly From Tablets & Smartphones
Hurry, only 1 left in stock!
£59.43
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Compact and reliable
The WorkForce WF-2510WF uses Epson's fast drying DURABrite Ultra Ink for professional-quality business documents and means that prints are water, smudge and highlighter resistant. Cartridges are also available in XL size, helping to save further on costs, as users can print up to 2.5x more pages(1).
This printer also has flexible connectivity options, as users can connect the printer to their network via Wi-Fi. With automatic Wi-Fi set-up, users don't need to know their network settings or connect with a USB cable during set up, as the printer automatically finds the relevant connection settings in order to configure itself(2).
Epson iPrint allows users to print wirelessly from smartphones and tablet PCs within the office (3).
The WorkForce WF-2510WF also comes with a robust 100-sheet rear paper tray, providing media flexibility for a variety of paper.
Wi-Fi all-in-one
Print, scan, copy and fax
Epson iPrint
Print from smartphones and tablet PCs
Space saving
Compact footprint
Economical
Print more pages with Epson XL inks(1)
Durable
3,000 page duty cycle per month(4)
  1. For more information, please visit www.epson.eu/inkjetsaving
  2. Automatic set-up compatible with Windows 8, Windows 7, Windows Vista and Mac OS
  3. Requires a wireless connection to the internet. For more information, supported languages and devices please visit www.epsonconnect.eu
  4. The maximum number of printed pages per month based on the performance capabilities of the printer, including ISO rated print speeds and paper handling capabilities
Epson WorkForce WF-2510WF - multifunction printer ( colour )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet ( colour )
Inkjet Technology
4-ink
Monthly Duty Cycle (max)
3000 impressions
Max Printing Speed
Up to 34 ppm (mono) / up to 18 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
1200 x 2400 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
100 sheets
PC Connection Availability
PC Connection
USB 2.0, Wi-Fi(n)
AC 230 V ( 50/60Hz )
39.2 cm x 37.7 cm x 17.7 cm
5 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
3000 impressions
PC Connection
USB 2.0, Wi-Fi(n)
Printing
Nozzle Configuration
180 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3 pl
Ink Type
Epson DURABrite Ultra inks
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Total Memory Capacity
Up to 180 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
60 station(s)
Automatic redialing, colour faxing
Document & Media Handling
Original Type
Sheets
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets
Speed Details
Printing: up to 34 ppm - B/W , Printing: up to 18 ppm - colour , Printing: up to 9 ppm - B/W (ISO/IEC 24734) , Printing: up to 4.7 ppm - color (ISO/IEC 24734) , Printing: 38 sec ( 10 x 15 cm (4"x6") ) - photo
1 x USB 2.0
Operating System Support
MS Windows XP, MS Windows 7, Apple Mac OS X 10.6.x, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Vista (64-bit versions), Apple Mac OS X 10.5.8 or later, MS Windows 8
Software Included
Epson Event Manager, EpsonNet Setup Manager, Epson Fax Utility, Presto! PageManager 9
11 Watt
Power Consumption Sleep
2.3 Watt
Consumables Included
1 x Cartridge ( black ) , 1 x Cartridge ( cyan ) , 1 x Cartridge ( magenta ) , 1 x Cartridge ( yellow )
Limited warranty - 1 year - carry-in
39.2 cm
37.7 cm
17.7 cm
5 kg
Shipping Width
45.6 cm
Shipping Depth
45.7 cm
Shipping Height
26.1 cm
Shipping Weight
6.3 kg
Sound Emission
36 dBA (operating)
Accessories
£7.64
£6.25
£6.25
£10.03
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Item has been used and shows signs of use.
Ref: 8F1T 034552
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£20.22
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
