BT.com
Wishlist
Epson Workforce Pro WF-5690DWF A4 Colour Inkjet Multifunction Printer
Delivery
Standard Due date unavailable
Low running costs
The WorkForce Pro WF-5690DWF has an up to 50 percent lower cost per page than competitive colour lasers, saving you money as you take advantage of this printer's high capacity ink cartridges of up to 4,000 pages². And there are fewer parts to replace than a laser.
Ecological
The WF-5690DWF uses up to 80 percent less power than competitive colour lasersthanks, in part, to its no heat technology. No ozone gases are emitted, and an improved quiet print mode and no fan noise during or after printing makes it ideal for the work environment.
Save time
This efficient multifunction business printer is faster than a laser on typical print jobs¹, with print speeds of up to 34ppm in mono and 30ppm in colour, or 20ppm ISO print speed in both³. Its high paper capacity of 580 sheets means less time is spent refilling, and it has a high monthly duty cycle of up to 35,000 pages4.
Built for business
PrecisionCore technology powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing. Prints dry fast thanks to the DURABrite Ultra ink. Scan-to functions, LDAP support and PDL emulations help this printer easily integrate into the business environment. Its intuitive large colour touch-screen makes functions readily available, and the rear manual paper tray lets you print on a range of media.
Epson WorkForce Pro WF-5690DWF - multifunction printer (colour)
Multifunction printer
Fax Type
Plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
35000 pages
Max Printing Speed
Up to 34 ppm (mono) / up to 30 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
330 sheets
Max Media Capacity
580 sheets
Bypass Feeder Capacity
80 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to folder, scan to Cloud
AC 230 V
46.1 cm x 44.2 cm x 34.2 cm
14.3 kg
Microsoft Certification
Compatible with Windows 7
1 year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
35000 pages
Display Features
Touch screen
AirPrint Enabled
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
400 nozzles (black), 3 x 400 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
2.8 pl
Printer Drivers / Emulations
PCL 5e, PCL 6, PCL 5c, PDF 1.7
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
First Print Out Time B/W
7 sec
First Print Out Time Colour
7 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Automatic redialing, e-mail function, colour faxing
Document & Media Handling
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
330 sheets
Max Media Capacity
580 sheets
80 sheets
150 sheets
Input tray - 250 sheets , Bypass tray - 80 sheets , Output tray - 150 sheets , ADF - 35 sheets
Speed Details
Printing: up to 20 ppm - B/W (ISO/IEC 24734) , Printing: up to 20 ppm - color (ISO/IEC 24734) , Printing: up to 30 ppm - colour , Printing: up to 34 ppm - B/W , Printing: up to 11 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 11 ppm (A4) - color (ISO/IEC 24734)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
WEP, WPA-PSK, TKIP, AES
Operating System Support
MS Windows XP Professional x64 Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, Apple Mac OS X 10.7.x, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6 or later, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits)
Software Included
Drivers & Utilities
AC 230 V
22 Watt
Power Consumption Standby
8.9 Watt
Power Consumption Sleep
2.6 Watt
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
Limited warranty - 1 year - on-site
46.1 cm
44.2 cm
34.2 cm
14.3 kg
Sound Emission
52 dBA (operating)
Accessories
Epson Matte Paper Heavyweight A4 50 sheets
Quicklinx: N6V | In Stock
£10.71
£13.99
Scroll to top
