BT.com
Wishlist
Epson Workforce DS 860 and Workforce Pro WF-5190 Bundle
Delivery
Standard Due date unavailable
With fast data processing, this sheet-fed scanner is ideal for quick and easy document workflow.
Performance and productivity
this scanner features a compact footprint and high-speed scanning of up to 65ppm / 130ipm, even at 300dpi in colour. This, combined with hardware JPEG compression, makes large scan jobs faster to process. Its ReadyScan technology certifies mercury-free products and guarantees no warm-up time before scanning.
Seamless integration into document management and cloud systems
Epson Document Capture Pro makes it easy to integrate this business scanner into your document management system, speeding up workflow and enabling you to capture, convert and distribute scanned information into your document filing system. In addition, barcode recognition and Zonal OCR help automate large document processes, such as file naming and folder creation. The DS-860 is easy to integrate into almost any document management system and workflow process thanks to WIA, TWAIN and ISIS driver support.
Scan software included
Epson Scan offers a wide selection of advanced document imaging features, such as text enhancement and automatic de-skew, which help improve efficiency and increase workload output. The DS-860 also scans to .docx, .xlsx and .pptx.
Easy network sharing via Ethernet
Optional Network Interface Unit is also available.
WorkForce Pro WF-5190DW
Take advantage of low running costs, low power consumption, fast print speeds and features designed for easy business integration with the new WorkForce Pro WF-5190DW. This business inkjet printer benefits from automatic double-sided printing, making any job easy and efficient, and PDL emulations, including PCL and Adobe PostScript 3.
Low running costs
The WorkForce Pro WF-5190DW has an up to 50 percent lower cost per page than competitive colour lasers1 , saving you money as you take advantage of this printer's high capacity ink cartridges of up to 4,000 pages2. And there are fewer parts to replace than a laser.
Save time
This efficient business printer is faster than a laser on typical print jobs1, with print speeds of up to 34ppm in mono and 30ppm in colour, or 20ppm ISO print speed in both3. Its high paper capacity of 580 sheets means less time is spent refilling, and a monthly duty cycle of up to 35,000 pages4 means you can print lots in confidence.
Ecological
The WF-5190DW uses up to 80 percent less power than competitive colour lasers1 thanks, in part, to its no heat technology. No ozone gases are emitted and an improved quiet print mode and no fan noise during or after printing makes it ideal for the work environment.
Built for business
PrecisionCore technology powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing. Prints dry fast thanks to the DURABrite Ultra ink. Print securely with Email Print for Enterprise. Epson Connect5 lets you easily print from smartphones, tablets and more, and its Wi-Fi Direct™ capability lets you print from supported wireless devices without connecting to a router.
Epson WorkForce DS-860 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Light Source
LED
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
65 ppm (mono) / 65 ppm (colour)
Max Document Size
216 mm x 356 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
6000 scans per day
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8, Microsoft Windows Server 2012 x64 Edition
Microsoft Certification
Compatible with Windows 7
30 cm x 16.6 cm x 15.8 cm
4 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
A4 (210 x 297 mm)
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
65 ppm
Max Document Scan Speed Colour
65 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
65 ppm - black & white - A4 - 300 dpi , 130 ipm - duplex - black & white - A4 - 300 dpi , 65 ppm - colour - A4 - 300 dpi , 130 ipm - duplex - colour - A4 - 300 dpi
Scanner Features
EPSON ReadyScan LED Technology, Automatic Separation, Barcode Detection, Auto Document Rotation, Punch Hole Removal, A3 stitching
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 356 mm
Automatic
80 sheets
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
Software Included
EPSON Scan, EPSON Document Capture Pro
30 cm
16.6 cm
15.8 cm
4 kg
5 °C
35 °C
Scroll to top
