BT.com
Wishlist
Epson WorkForce DS-560 wi-fi Document Scanner
Delivery
Standard Due date unavailable
A4 sheet-fed scanner
Performance and productivity This compact scanner has scanning speeds of up to 26ppm / 52ipm, even at 300dpi in colour. This, combined with hardware JPEG compression, makes large scan jobs faster to process.
Seamless integration into document management and cloud systems Epson Document Capture and Document Capture Pro make it easy to integrate this scanner into your document management system, speeding up workflow and enabling you to capture, convert and distribute scanned information into your document filing systems. In addition, the Pro version for Windows offers barcode recognition and Zonal OCR to help automate document processes, such as file naming and folder creation.
Scan software included or download our new free app Epson Scan1 offers a wide selection of advanced document imaging features, including text enhancement and automatic de-skew, which help improve efficiency and increase workload output. This model also scans to .docx, .xlsx and .pptx. Scan to your Android or Apple mobile device by downloading the new Epson DocumentScan app from Google Play or the Apple App Store.
Flexible connectivity Wi-Fi, Wi-Fi DirectTM and USB interfaces allow you to conveniently connect to this scanner.
Key Features -High-speed scanning Scanning speeds of up to 26ppm / 52ipm, even at 300dpi in colour -Flexible connectivity Wi-Fi and Wi-Fi DirectTM connectivity, plus a USB interface -Fast processing Hardware JPEG compression -Seamless integration into document management and cloud systems Epson Document Capture and Document Capture Pro -Scan software/app for PC, Mac, mobile Advanced document imaging features help improve efficiency
  1. To use this app, connect from a mobile device to the DS-560 via Wi-Fi or Wi-Fi DirectTM. Load documents onto the DS-560 and start scanning via the app on your mobile device. Simply choose your settings, press 'Scan', view the scanned image on the screen and export it to cloud services or other document management systems.
Epson WorkForce DS-560 - document scanner - desktop - USB 2.0, Wi-Fi(n)
Document scanner - desktop
Interface Type
USB 2.0, Wi-Fi(n)
Light Source
LED
Additional Functions
Email, scan to server
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
26 ppm (mono) / 26 ppm (colour)
Max Document Size
216 mm x 914 mm
Automatic Duplexing
Supported Document Type
Plain paper, card scanner, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
3000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8
Microsoft Certification
Compatible with Windows 7
29.7 cm x 15.2 cm x 15.4 cm
2.5 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Interface Type
USB 2.0, Wi-Fi(n)
A4 (210 x 297 mm)
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
26 ppm
Max Document Scan Speed Colour
26 ppm
Duty Cycle
3000 scans per day
Scanner Speed Details
26 ppm - black & white - A4 - 300 dpi , 52 ipm - duplex - black & white - A4 - 300 dpi , 26 ppm - colour - A4 - 300 dpi , 52 ipm - duplex - colour - A4 - 300 dpi
Scanner Features
EPSON ReadyScan LED Technology, Automatic Separation, Barcode Detection, Auto Document Rotation, Punch Hole Removal, A3 stitching
TWAIN, WIA
Media Handling
Max Document Size
216 mm x 914 mm
Automatic
50 sheets
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
Software Included
ABBYY FineReader 9.0 Sprint, EPSON Document Capture Pro, ABBYY FineReader 8.0 Sprint for MAC
29.7 cm
15.2 cm
15.4 cm
2.5 kg
Limited warranty - 1 year - on-site
Scroll to top
