BT.com
Wishlist
Epson Stylus Photo PX730WD - multifunction ( printer / copier / scanner ) ( colour )
Delivery
Standard Due date unavailable
Ideal for photo printing
For anyone who isn't willing to settle for just lab-quality results when printing their photos, Epson's unique Claria Photographic Ink has been developed to deliver better-than-lab-quality results with every print job. You get great value with a choice of cartridge sizes and, with individual inks, you only need to replace the color used. The ideal partner for the latest DSLR and compact cameras, high-quality prints can be achieved every time with this high-definition ink that's also versatile enough for the whole household to use for their non-photo printing needs. Additionally, the dual paper trays allow you to effortlessly switch between A4 sized and photo sized paper during printing, by automatically selecting the correct tray.
Automatic Wi-Fi set-up
Configuring laptops and computers to print wirelessly is much easier with the automatic Wi-Fi set-up*1. You don't need to know your network settings or connect with a USB cable, the PX730WD automatically finds the relevant connection settings and configures itself. Multiple users then have the freedom to print, copy and scan quickly and efficiently from anywhere in the home.
Mobile printing
The PX730WD is also compatible with Epson iPrint which offers even more flexibility and freedom, allowing you to quickly and easily print photos and documents wirelessly from smartphones and tablet PCs*2.
Ease of use
The smart-navigation touch-panel highlights relevant buttons, guiding you through the printing process, while the large 6.3cm colour LCD screen and accompanying PictBridge and memory card slots offer easy-to-use PC-free photo printing. No more waiting for computers to power up; printing directly from a memory card allows greater flexibility and is straightforward. The front-loading paper trays offer easy access while keeping the paper neatly out of sight.
High performance
This highly efficient all-round printer comes with fast print speeds and double-sided document printing. It also has the ability to print directly onto suitable CD and DVDs, which you can use to personalise family films and digital photo albums to create homemade gifts.
Epson Stylus Photo PX730WD - multifunction printer ( colour )
Printer / copier / scanner
Copier Type
Digital
Printing Technology
Ink-jet ( colour )
Inkjet Technology
Epson Micro Piezo - 6-ink
Max Printing Speed
Up to 40 ppm (mono) / up to 40 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
2400 x 4800 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm) (max)
Media Type
Envelopes, plain paper, photo paper, printable CD/DVD disc
Standard Media Capacity
120 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, USB host, Wi-Fi
Office Machine Features
Print from memory card
AC 230 V
44.5 cm x 45.8 cm x 15 cm
9.8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Copier Type
Digital
Printing Technology
Ink-jet - colour - photo
PC Connection
Supported Flash Memory
Memory Stick, CompactFlash, SD Memory Card, MultiMediaCard, xD-Picture Card, Memory Stick PRO, IBM Microdrive, MultiMediaCardplus, SDHC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (per cartridge)
Max Printing Speed
Ink Cartridge Configuration
6 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, light cyan, light magenta
6-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Epson Claria Photographic Ink
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
2400 x 4800 dpi
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
120 sheets
Input tray - 120 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 40 ppm ( A4 ) - B/W , Printing: up to 40 ppm ( A4 ) - colour , Printing: 10 sec ( 10 x 15 cm (4"x6") ) - photo
1 x USB 2.0 , 1 x USB host , 1 x LAN
Security Protocols & Features
WEP, WPA-PSK
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.4.11 or later
Software Included
Epson Event Manager, EPSON Print CD, Epson Easy Photo Print, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint for Mac
AC 230 V
23 Watt
Power Consumption Sleep
5 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x Cartridge ( black ) , 1 x Cartridge ( cyan ) , 1 x Cartridge ( magenta ) , 1 x Cartridge ( yellow ) , 1 x Cartridge ( light cyan ) , 1 x Cartridge ( light magenta )
Limited warranty - 1 year
44.5 cm
45.8 cm
15 cm
9.8 kg
Sound Emission
35 dBA (operating)
Accessories
£15.67
£11.52
Epson Matte Paper Heavyweight A4 50 sheets
Quicklinx: N6V | In Stock
£11.14
£14.24
Scroll to top
