BT.com
Wishlist
Epson LX 1170 II Mono Dot-Matrix Printer
Delivery
Standard Due date unavailable
This wide-carriage 9-pin printer fits perfectly into a range of environments including data reporting, listings and point-of-sale. It is 337 cps fast, very reliable and cost efficient and has a range of options so you can create the perfect high quality printer to match your changing business requirements.
Flexible working
Handle light duties in style with printing up to A3 size, 5-part forms (1 original + 4 copies) and 337 cps (12cpi) speed.
Get connected
Enjoy no-fuss support for a range of office equipment with auto switching between USB, parallel and serial sources.
Optional extras
Choose from a wide range of options to match changing needs, including a 50 cut-sheet feeder, roll paper holder and wired or wireless networking.
Epson LX 1170 II - printer - monochrome - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 9 pin - monochrome
6.3 kg
Max Media Size
364 x 420 mm, continuous paper 102 mm - 406 mm (width)
Max Media Size (Custom)
420 mm x 559 mm
Print Speed
Up to 337 char/sec - fast draft , Up to 300 char/sec - fast draft , Up to 270 char/sec - draft , Up to 67 char/sec - condensed , Up to 56 char/sec - condensed
Parallel, USB, serial
RAM Installed (Max)
64 KB
Language Simulation
EPSON ESC/P 2, IBM 2381 Plus
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Microsoft Windows NT 4.0, Microsoft Windows 95/98, Microsoft Windows 3.1, Microsoft Windows 2000, Microsoft Windows NT 3.5
Microsoft Certification
Works with Windows Vista
1 year warranty
54.6 cm x 27.5 cm x 16.3 cm
Printer Type
Printer
Print Speed
Up to 337 char/sec - fast draft - 12 cpi , Up to 300 char/sec - fast draft - 10 cpi , Up to 270 char/sec - draft - 12 cpi , Up to 67 char/sec - condensed - 12 cpi , Up to 56 char/sec - condensed - 10 cpi
Wired
Language Simulation
Fonts Included
8 x barcode
Barcodes
RAM
RAM Installed (Max)
64 KB
Media Handling
Max Media Size
420 mm x 559 mm
Media Sizes
Max Sheets in Multi-Part Form
5
1 x parallel - 36 PIN Centronics , 1 x serial - 9 pin D-Sub (DB-9) , 1 x USB
MTBF
6,000 hour(s)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
Software Included
Drivers & Utilities
Limited warranty - replacement - 1 year
35 °C
Sound Emission (Operating)
49 dBA
54.6 cm
27.5 cm
16.3 cm
6.3 kg
Accessories
Epson Black Fabric Ribbon
Quicklinx: 3KND | In Stock
£5.25
Scroll to top
