BT.com
Wishlist
Epson LabelWorks LW-900P Label Printer
Epson LabelWorks LW-900P Label...
£178.44
£178.44
Add to wishlist
Delivery
Standard Due date unavailable
Design labels easily
Creating labels is easy using the included software with intuitive menus. Choose from pre-loaded label templates, or design your own and store them on your computer. A special toolbar enables you to add pre-defined frames, symbols, barcodes and text enhancements, or import images. In just a few steps, your label is ready to print.
Import and print data
Using the software, you can import data in csv, txt and xls(x) formats, create a layout corresponding to the column headings, and then print labels for each line of data. You can also print a series of labels with incremental dates or figures.
Convenient
Producing labels is a hassle-free process from start to finish, as the LW-900P automatically detects the tape width, and automatically cuts or half-cuts the labels once printed. Its convenient integrated trimmer can round label edges, and a dedicated window displays how much tape remains.
Flexible tape options
Epson's wide selection of labels in 6, 9, 12, 18, 24 and 36mm sizes cover virtually every labelling need, with transparent labels, cable wraps, writable matte paper labels and more, plus a choice of adhesive strengths and colour combinations. All Epson labels are very durable, resisting water and withstanding hot and cold conditions.
Economical
The LW-900P minimises label margins, meaning you get more labels per tape, and Epson's 9-metre label tape offers economical refills. Two four-metre label tapes are included to get you started.
Epson LabelWorks LW-900P - labelmaker - monochrome - thermal transfer
Printer Type
Labelmaker - thermal transfer - monochrome
0.9 kg
Max Media Size
Roll (3.6cm)
Print Speed
Up to 25 mm/sec
Max Resolution (B&W)
360 dpi
USB
Barcodes
Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, ITF
Styles & Effects
Vertical, Mirror
Apple MacOS, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Microsoft Certification
Compatible with Windows 7
2 years warranty
18.2 cm x 8.5 cm x 14.6 cm
Printer Type
Enclosure Colour
Pale grey
Printer
Print Speed
Up to 25 mm/sec
Built-in Devices
Cutter
Wired
USB
360 dpi
Styles & Effects
Vertical, Mirror
Auto Cutter
Barcodes
Media Handling
Max Media Size
Roll (3.6cm)
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (3.6cm)
1 x USB - 4 pin USB Type B
Power adapter - external
13.6 Watt
Power Consumption Stand by / Sleep
0.7 Watt
Software Included
Epson Label Editor
Environmental Standards
ENERGY STAR
18.2 cm
8.5 cm
14.6 cm
0.9 kg
Scroll to top
