BT.com
Wishlist
Epson LabelWorks LW-700 Label Printer
Delivery
Standard Due date unavailable
Connect the LW-700 to your computer and you can create labels the way you want to, thanks to the included Label Editor Software. Design your own labels and store them on your computer, or choose from a variety of templates.
Using a special toolbar, you can add frames, symbols, barcodes and images for full customisation. With the data import function you can also choose to print one label up to 999 times, or 999 different labels, in a single print job – ideal for large office projects.
Unplug the LW-700 from your PC, and your desktop model instantly turns into a portable label maker. You can easily create labels away from the office thanks to its embedded keyboard, a wide variety of functions, dedicated access keys and carry handle. With its print-preview graphic display, you can see what your labels will look like before you print them, saving you time and money on unnecessary printing.
Choose from the large collection of 460 symbols and, with the ability to save up to 100 designs in the internal memory, you'll always have the right designs when you need them. Margins can be minimised down to 1mm, meaning you get more labels per tape, and you can print labels up to 24mm in width.
To help get you started, the LW-700 is supplied with one nine-metre tape while the large variety of tapes available ensure you're able to select the ideal tape for your particular task.
Epson LabelWorks LW-700 - labelmaker - monochrome - thermal transfer
Printer Type
Labelmaker - thermal transfer - monochrome
770 g
Max Media Size
Roll (2.4 cm)
Print Speed
Up to 13 mm/sec
Max Resolution (B&W)
180 dpi
USB
Barcodes
Code 39, GS1 DataBar, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, ITF
Fonts
Sans Serif, Gothic
Styles & Effects
Bold, italic bold, italic outline, italic shadow, outline shadow, normal, vertical, outline, shadow, italic, Mirror, underline
Display Resolution
4 lines x 16 characters / 130 x 64
Keyboard
QWERTZ / 63 keys
Required 6 x AA type
Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4 or later, Windows 8
Enclosure Colour
Green, pale grey
18 cm x 23.5 cm x 8 cm
Printer Type
Enclosure Colour
Green, pale grey
Printer
Print Speed
Up to 13 mm/sec
Built-in Devices
Preview screen, character keyboard, cutter
Wired
USB
180 dpi
Fonts
Sans Serif, Gothic
Styles & Effects
Display Resolution
Keyboard
QWERTZ / 63 keys
Repeating Printing
999 copies
Barcodes
Media Handling
Max Media Size
Roll (2.4 cm)
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm)
Max Printing Width
18 mm
1 x USB - 4 pin USB Type B
1 x USB cable
Media Included
Roll of media
Power adapter - external
6.99 Watt
AA type
Required Qty
6
Software Included
Drivers & Utilities, Epson Label Editor
System Requirements Details
HD 100 MB
Environmental Standards
ENERGY STAR
18 cm
23.5 cm
8 cm
770 g
Scroll to top
