The LW-400VP is straightforward to use and ideal for busy work environments away from the office. Dedicated buttons give quick access to cutting and printing functions, while an internal memory allows you to save and recall your favourite 50 label designs at any time.
The smart, black design helps keep the label maker free from smears and fingerprints, while its black rubber casing provides a protective barrier against scratches and drops. Its black sturdy carry case enables you to transport it easily and safely, and gives you room to take the AC adaptor and up to six tapes with you.
The LW-400VP minimises label margins, meaning you get more labels per tape, and Epson's nine-metre label tape offers economical refills. You don't need to replace tapes quite so often. Two four-metre label tapes are included to get you started – black text on standard white tape, 12mm wide, and black text on strong adhesive yellow tape, 9mm wide.
The label maker prints up to four lines and offers excellent versatility thanks to a large number of formats, symbols and font designs. You can see how your labels will look – even in darkness or bright sunlight – thanks to the LW-400VP's backlit LCD screen.
