BT.com
Wishlist
Epson LabelWorks LW-300 Label Printer
Epson LabelWorks LW-300 Label...
£37.82
£37.82
Add to wishlist
Delivery
Standard Due date unavailable
Easy-to-use label maker
With its ergonomic buttons, integrated keyboard and high-quality LCD screen, the LW-300 is simple to use. Dedicated buttons give quick access to cutting and printing functions, while an internal memory allows you to save and recall your favorite label designs at any time. The amount of tape remaining can be checked at any time using the dedicated window.
Easy to use
With its ergonomic buttons, integrated keyboard and high-quality LCD screen, the LW-300 is simple to use. Dedicated buttons give quick access to cutting and printing functions, while an internal memory allows you to save and recall your favourite 30 label designs at any time. The amount of tape remaining can be checked at any time using the dedicated window.
Versatile
Fitting easily onto your desktop, the LW-300 can be used with the included AC adaptor, or loaded with batteries for label printing on the go. It prints up to two lines and offers excellent versatility with 14 font types, 5 character sizes, 457 symbols, 87 borders and 10 styles, including bold, italic, outline and shadow.
Flexible tape options
Epson's wide selection of tapes in 6, 9 and 12mm sizes cover virtually every office labelling need. The range includes standard, black, transparent and writable matte paper labels, a variety of colours including fluorescent and pastel, and two adhesive strengths. All Epson labels are durable, resisting water and withstanding hot and cold conditions.
Economical
The LW-300 minimises label margins, meaning you get more labels per tape, and Epson's 9-metre label tape offers economical refills. Two four-metre label tapes are included to get you started.
Dedicated buttons
For cutting and printing
Flexible formatting
Choice of fonts, styles and borders
Choice of tapes
Supports 6, 9 and 12mm labels
Minimal margins
Mean more labels per tape
9-metre tape
For economical refills
Epson LabelWorks LW-300 - labelmaker - monochrome - thermal transfer
Printer Type
Labelmaker - thermal transfer - monochrome
Portable
435 g
Max Media Size
Roll (1.2 cm)
Max Resolution (B&W)
180 dpi
Fonts
Sans Serif, Gothic
Styles & Effects
Bold, italic bold, italic outline, italic shadow, outline shadow, normal, vertical, outline, shadow, italic, Mirror, italic outline shadow
2 line printing
Display Resolution
1 line x 16 characters
Keyboard
59 keys
Required 6 x AAA type Included Qty 0
2 years warranty
14.5 cm x 15 cm x 5.5 cm
Printer Type
Enclosure Colour
White
Printer
Built-in Devices
Preview screen, character keyboard, cutter
180 dpi
Fonts
Sans Serif, Gothic
Styles & Effects
2 line printing
Display Resolution
Keyboard
59 keys
Repeating Printing
9 copies
Media Handling
Max Media Size
Roll (1.2 cm)
Media Sizes
Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm)
Max Printing Width
9 mm
Max Printing Length
400 mm
Power adapter - external
2.28 Watt
Power Consumption Stand by / Sleep
0.18 Watt
AAA type
Required Qty
6
Included
0
14.5 cm
15 cm
5.5 cm
435 g
Scroll to top
