BT.com
Wishlist
Epson GT-S85N A4 Document Scanner
Delivery
Standard Due date unavailable
High-quality productivity: The GT-S85N produces scans at speeds of up to 40 pages per minute in simplex or 80 images per minute in duplex, in mono and colour, at 200dpi. Double-sided pages are scanned in a single pass, while a 75-sheet automatic document feeder is perfect for large-volume jobs. For extra reliability, an ultrasonic sensor detects and easily recovers paper jams.
Easy to integrate: Designed to fit into virtually any document management system, the GT-S85N is fully compatible with complex IT environments. It also comes network-ready for sharing between multiple users.
Simplify tasks: Complicated jobs, such as organising documents and reports, converting business cards into a database or enhancing text, become effortless thanks to Epson's advanced software and imaging technology. Customise up to 10 'scan to job' functions to scan and send files where you want them with a single touch of a button.
Eco-friendly: Epson ReadyScan LED technology means no warm-up time and lower power consumption, reducing costs and environmental impact. The GT-S85N is a mercury-free product, making it more environmentally-conscious.
Epson GT S85N - document scanner - desktop - USB 2.0, LAN
Document scanner - desktop
Interface Type
USB 2.0, LAN
Scan Element Type
CCD
Light Source
LED
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
216 mm x 914 mm
Automatic Duplexing
Supported Document Type
Plain paper, card scanner
Document Feeder Type
Automatic
Document Storage Capacity
75 sheets
Duty Cycle
3000 scans per day
AC 230V (50 Hz)
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
30.3 cm x 20.2 cm x 21.3 cm
5 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Interface Type
USB 2.0, LAN
A4 (210 x 297 mm)
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Scan Element Type
CCD
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Duty Cycle
3000 scans per day
Scanner Speed Details
40 ppm - black & white - A4 - 200 dpi , 40 ppm - colour - A4 - 200 dpi , 40 ppm - greyscale - A4 - 200 dpi , 80 ipm - duplex - black & white - A4 - 200 dpi , 80 ipm - duplex - colour - A4 - 200 dpi , 80 ipm - duplex - greyscale - A4 - 200 dpi
Scanner Features
EPSON ReadyScan LED Technology, Ultrasonic multifeed sensor
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 914 mm
Automatic
75 sheets
USB 2.0 - Type B , LAN
1 x USB cable
ENERGY STAR Certified
External power adapter
AC 230V (50 Hz)
Power Consumption Operational (Standby)
45 Watt (5 Watt)
Software Included
ABBYY FineReader 6.0 Sprint Plus, Presto! BizCard 5, Presto! PageManager 8 Professional, ABBYY FineReader 5.0 Sprint Plus for Mac, EPSON Event Manager 2.6, EPSON Event Manager 2.3, EPSON Copy Utility 3.5, Presto! BizCard 5.6, EPSON Scan 3.67, EPSON Scan 3.65
30.3 cm
20.2 cm
21.3 cm
5 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
10 - 80%
Scroll to top
