BT.com
Wishlist
Epson Expression XP-760 3 in 1 Photo Printer with WiFi
Epson Expression XP-760 3 in 1...
£159.49
£159.49
Add to wishlist
Delivery
Standard Due date unavailable
Superior results
The XP-760 uses a six-colour inkset to deliver smooth tonal gradations, natural blacks and rich, vibrant colours for superior-quality photos.
Mobile printing
Epson Connect consists of Epson iPrint – for easy wireless printing from smartphones and tablets; Epson Creative Print – print photos directly from Facebook, and Epson Email print – print from anywhere in the world by emailing photos and documents directly to the printer. AirPrint and Google Cloud Print are also supported.
Wireless connectivity
Automatic Wi-Fi set-up4 makes it quick and simple to connect to a Wi-Fi network or, alternatively, compatible devices can be connected via Wi-Fi Direct without having to connect to a wireless router. Printing is also possible from Wireless PictBridge-compatible cameras.
Versatile printing
In addition to dual paper trays, the rear speciality media feed enables printing onto thick card and photo paper. Printing onto suitable CDs and DVDs is also possible, further expanding the possibilities. Fast print speeds mean you can print photos in just 10 seconds5.
Easy to control
As well as a motorised control panel and output tray and a 10.9cm interactive LCD touch-screen, the XP-760 includes a memory card slot for PC-free operation. Auto Power On automatically turns the printer on and opens the control panel and output tray when you start printing.
Epson Expression Photo XP-760 - multifunction printer (colour)
Printer / copier / scanner
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 6-ink
Max Printing Speed
Up to 32 ppm (mono) / up to 32 ppm (colour)
Max Printing Resolution
Up to 5760 x 1400 dpi (mono) / up to 5760 x 1400 dpi (colour)
Scanning
2400 x 4800 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, Google Cloud Print ready, scan to Cloud
AC 230 V (50/60Hz)
39 cm x 34.1 cm x 14.1 cm
6.9 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
Display Features
Touch screen
PC Connection
AirPrint Enabled
Supported Flash Memory
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (per cartridge)
Max Printing Speed
Ink Cartridge Configuration
6 cartridges (1 each: light cyan, light magenta, yellow, black, magenta, cyan)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, light cyan, light magenta
6-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Epson Claria Photo HD Ink
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
2400 x 4800 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
90 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 32 ppm - B/W , Printing: up to 32 ppm - colour , Printing: up to 9.5 ppm - B/W (ISO/IEC 24734) , Printing: up to 9 ppm - color (ISO/IEC 24734) , Printing: 10 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
WEP, WPA-PSK, TKIP, AES
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.6.8 or later, Windows 8
Software Included
EPSON Print CD, Epson Easy Photo Print
AC 230 V (50/60Hz)
20 Watt
Power Consumption Standby
6.6 Watt
Power Consumption Sleep
1.4 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow) , 1 x Cartridge (light cyan) , 1 x Cartridge (light magenta)
EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15 B, EN 60950-1, CAN/CSA C22.2 No. 60950-1, UL60950-1
ENERGY STAR Certified
39 cm
34.1 cm
14.1 cm
6.9 kg
10 °C
35 °C
20 - 80% (non-condensing)
Other bundles
£159.49
Keep your electronic devices protected
£179.48
Accessories
£15.67
£11.24
Epson A4 Photo Self - Adhesive 10sht
Quicklinx: D9X | In Stock
£10.96
Epson Matte Paper Heavyweight A4 50 sheets
Quicklinx: N6V | In Stock
£11.07
£14.24
Scroll to top
