BT.com
Wishlist
Epson Expression Home XP-305 - Multifunction - Colour - Inkjet - 33 ppm - Wi-Fi
Delivery
Standard Due date unavailable
Wi-Fi Small-In-One with LCD screen
The Epson Expression Home XP-305 is part of the Small-in-One range - Epson's smallest ever range of all-in-one home inkjets. This printer, scanner and copier offers cost-effective printing for home users who are looking for the added benefit of Wi-Fi connectivity as well as mobile printing.
The Epson Expression Home XP-305 comes with Epson Connect, offering even more flexibility and freedom. It allows users to quickly and easily print documents and photos wirelessly from smartphones and tablet PCs. Additionally, users can print from anywhere in the world by emailing documents and photos directly to the printer.
The XP-305 is Apple AirPrint ready and makes it simple to print emails, photos, web pages and documents directly from iOS devices.
Meanwhile, Google Cloud Print is also supported and allows users to print on the go from a smartphone or computer.
The automatic Wi-Fi set-up makes configuring laptops and computers to print and scan wirelessly extremely easy, as the XP-305 automatically finds the relevant connection settings in order to configure itself. In addition, a 3.6cm colour LCD screen and accompanying memory card slot offers easy-to-use printing with helpful menu prompts.
Epson's new, Claria Home Ink is ideal for affordable reliable printing, producing crisp, clear text documents and glossy, lab-quality photos. With individual ink cartridges you only have to replace the colour used, saving you money.
Claria Home Ink cartridges are available in standard and XL sizes, with page yields displayed clearly on each pack. Identifying the right ink cartridge for your printer couldn't be simpler - just look out for the Daisy image.
Small-in-One
Save space, save money, save time
3.6cm LCD screen
PC-free printing
Epson Connect
Mobile printing over Wi-Fi and email
Auto Wi-Fi set-up
Easy to connect wirelessly
Individual Inks
Only replace the colour used
Epson Expression Home XP-305 - multifunction printer ( colour )
Printer / copier / scanner
Copier Type
Digital
Printing Technology
Ink-jet ( colour )
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 33 ppm (mono) / up to 15 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
1200 x 2400 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
PC Connection Availability
PC Connection
USB 2.0, Wi-Fi
AirPrint Enabled
Office Machine Features
Print from memory card, Google Cloud Print ready
AC 110/230 V ( 50/60Hz )
39 cm x 30 cm x 14.5 cm
4.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Copier Type
Digital
Printing Technology
Ink-jet - colour
PC Connection
USB 2.0, Wi-Fi
AirPrint Enabled
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3 pl
Ink Type
Epson Claria Home Ink
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Original Type
Sheets
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 8.7 ppm - B/W (ISO/IEC 24734) , Printing: up to 4.5 ppm - color (ISO/IEC 24734) , Printing: up to 33 ppm - B/W , Printing: up to 15 ppm - colour , Printing: 38 sec ( 10 x 15 cm (4"x6") ) - photo
1 x USB 2.0
Security Protocols & Features
WEP, WPA-PSK, TKIP, AES
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.5.8 or later
Software Included
Epson Event Manager, Epson Easy Photo Print, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint for Mac, Epson Connect
13 Watt
Power Consumption Sleep
2.7 Watt
Consumables Included
1 x Cartridge ( black ) , 1 x Cartridge ( cyan ) , 1 x Cartridge ( magenta ) , 1 x Cartridge ( yellow )
Supported Windows 7 Features
Windows XP Mode Compatibility
Limited warranty - 1 year - carry-in
39 cm
30 cm
14.5 cm
4.2 kg
Shipping Width
46.4 cm
Shipping Depth
38 cm
Shipping Height
20 cm
Shipping Weight
5.2 kg
Accessories
Epson XP30/302/405 Pack Of 4 Inks XL SIZE
Quicklinx: 89DC | In Stock
£56.24
£29.77
Epson XP30/202/302/405 Black Ink 11.5 ML
Quicklinx: 8MD8 | In Stock
£17.32
Epson Singlepack Black 18 Claria Home Ink
Quicklinx: 8QDW | In Stock
£8.85
Epson Singlepack Magenta 18 Claria Home Ink
Quicklinx: 8QDY | In Stock
£7.28
Epson Singlepack Yellow 18 Claria Home Ink
Quicklinx: 8QDZ | In Stock
£7.30
Epson Singlepack Cyan 18XL Claria Home Ink
Quicklinx: 8QF0 | In Stock
£13.09
£13.04
£13.09
Epson A4 Photo Self - Adhesive 10sht
Quicklinx: D9X | In Stock
£10.83
Epson Matte Paper Heavyweight A4 50 sheets
Quicklinx: N6V | In Stock
£11.08
£14.47
Scroll to top
