BT.com
Wishlist
Epson Expression Home XP-102 - printer / copier / scanner - colour
Delivery
Standard Due date unavailable
Epson's new, Claria Home Ink is ideal for affordable reliable printing, producing crisp, clear text documents and glossy, lab-quality photos. With individual ink cartridges you only have to replace the colour used, saving you money.
Claria Home Ink cartridges are available in standard and XL sizes, with page yields displayed clearly on each pack. Identifying the right ink cartridge for your printer couldn't be simpler – just look out for the Daisy image.
The new design, coupled with an ultra-compact footprint, means this Small-in-One complements any modern home environment without taking up too much space.
This printer is the complete package that helps users with a selection of tasks, from printing coursework and photos to scanning and copying important documents. The XP-102 is great value for money, ideal for users who want to spend their budget wisely.
Epson Expression Home XP-102 - multifunction printer ( colour )
Printer / copier / scanner
Copier Type
Digital
Printing Technology
Ink-jet ( colour )
Inkjet Technology
4-ink
Max Printing Speed
Up to 26 ppm (mono) / up to 13 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
600 x 1200 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
50 sheets
PC Connection Availability
PC Connection
USB 2.0
AirPrint Enabled
Office Machine Features
Google Cloud Print ready
AC 110/230 V ( 50/60Hz )
39 cm x 30 cm x 14.5 cm
3.9 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Ink-jet - colour
PC Connection
USB 2.0
AirPrint Enabled
Printing
Nozzle Configuration
128 nozzles (black), 3 x 42 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3 pl
Ink Type
Epson Claria Home Ink
Scanning
Scan Element
CIS
Optical Resolution
600 x 1200 dpi
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm)
50 sheets
Input tray - 50 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 6.2 ppm - B/W (ISO/IEC 24734) , Printing: up to 3.1 ppm - color (ISO/IEC 24734) , Printing: up to 26 ppm - B/W , Printing: up to 13 ppm - colour , 54 sec ( 10 x 15 cm (4"x6") ) - photo
1 x USB 2.0
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.5.8 or later
Software Included
Epson Event Manager, Epson Easy Photo Print, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint for Mac
11 Watt
Power Consumption Sleep
1 Watt
Consumables Included
1 x Cartridge ( black ) , 1 x Cartridge ( cyan ) , 1 x Cartridge ( magenta ) , 1 x Cartridge ( yellow )
39 cm
30 cm
14.5 cm
3.9 kg
Sound Emission
41 dBA (operating)
Accessories
Epson Matte Paper Heavyweight A4 50 sheets
Quicklinx: N6V | In Stock
£10.83
Scroll to top
