BT.com
Wishlist
Epson Expression 11000XL Pro Flatbed Colour A3 Scanner
Epson Expression 11000XL Pro...
£2,656.81
£2,656.81
Add to wishlist
Delivery
Standard 1-3 working days
Thanks to the Expression 11000XL Pro's top-of-the-range scanning technology, users can achieve extremely high-quality image reproduction up to A3 format. Easy-to-use, Epson Scan operates in automatic or professional modes, allowing users to optimize their scanning results.
The scanner's optical density of 3.8 DMax and 48-bit colour depth ensure sharp and accurate scanning for full reproduction of the widest range of colours, even in shadow areas. In addition, the high 2400 x 4800dpi resolution and ultra-precise Micro Step Drive technology, enable users to capture even the tiniest details with exceptional clarity.
A comprehensive package of bundled software and imaging technology enables the Expression 11000XL Pro to perform a wide range of functions easily and efficiently. Epson Scan comes with useful features for removing dust noise and grain reduction to smooth the appearance of images. SilverFast Ai8 is included for advanced users, with an intuitive user-friendly interface and processing functions to help get even closer to perfect image reproduction.
The included transparency unit enables users to scan from transparency media, such as positive or negative film and slides, with professional results.
Epson Expression 11000XL Pro - flatbed scanner
Flatbed scanner - desktop
Interface Type
USB 2.0
Light Source
Xenon gas fluorescent lamp
Max Supported Document Size
DIN A3 (310 x 437 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Optical Resolution
2400 dpi x 4800 dpi
Max Document Size
310 mm x 437 mm
Supported Document Type
Plain paper
Document Feeder Type
Manual
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5.8, Windows 8
65.6 cm x 45.8 cm x 29.2 cm
19.6 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Optical Resolution
2400 dpi x 4800 dpi
Scan Mode
Single-pass
Bulb / Light Source Type
Scan Density Range
3.8D
Scanner Speed Details
7 sec/scan - greyscale - 200 dpi , 7 sec/scan - colour - 200 dpi , 2.7 ms/line - greyscale , 8 ms/line - colour
Media Handling
Max Document Size
310 mm x 437 mm
Plain paper
Manual
USB 2.0 - Type B
Transparency adaptor, IT8 transparent calibration target
1 x USB cable
Internal power supply
Power Consumption Operational (Standby)
50 Watt
Software Included
Drivers & Utilities, EPSON Scan, SilverFast Ai Studio 8
65.6 cm
45.8 cm
29.2 cm
19.6 kg
5 °C
35 °C
10 - 80%
Scroll to top
