BT.com
Wishlist
Epson Expression 10000XL
Delivery
Standard Due date unavailable
Graphics quality:
Enjoy a level of detail which will satisfy the most demanding clients with 2400 x 4800 dpi resolution and advanced autofocus. Handle oversized originals with scanning up to A3+ size.
Fast capture:
The high bright xenon lamp gives you instant start up and fast scanning – just 32 seconds for a full colour reflective A3 original at 300 dpi, and 51.2 seconds for 35 mm film at 1600 dpi.
Optional extras:
The optional A3 transparency makes light work of film batches. There's an optional A3 auto document feeder for scanning up to 100 sheets at a time. And you can even share the scanner across your office with optional networking.
Epson Expression 10000XL - flatbed scanner - desktop - USB 2.0, FireWire
Flatbed scanner - desktop
Interface Type
USB 2.0, FireWire
Scan Element Type
CCD
Light Source
Xenon gas fluorescent lamp
Max Supported Document Size
DIN A3 (310 x 437 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
2400 dpi x 4800 dpi
Interpolated Resolution
12800 dpi x 12800 dpi
Max Document Size
310 mm x 437 mm
Supported Document Type
Plain paper
Document Feeder Type
Manual
AC 230V (50/60 Hz)
Apple MacOS 9.1, Microsoft Windows 98/ME, Microsoft Windows XP Home Edition, Microsoft Windows 2000 Professional / XP Professional, Apple MacOS X 10.2 or later
Microsoft Certification
Certified for Windows Vista
65.6 cm x 45.8 cm x 15.8 cm
14.5 kg
1 year warranty
Interface Type
USB 2.0, FireWire
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
2400 dpi x 4800 dpi
Scan Mode
Single-pass
Scan Element Type
CCD
Bulb / Light Source Type
Scan Density Range
3.8D
Scan Scaling
200%
Control Panel Buttons Functions
Scan
Scanner Speed Details
5.3 ms/line - greyscale - 2400 dpi , 16 ms/line - colour - 2400 dpi , 2.7 ms/line - greyscale - 1200 dpi , 8 ms/line - colour - 1200 dpi
TWAIN
Media Handling
Max Document Size
310 mm x 437 mm
Plain paper
Manual
USB 2.0 - Type B , FireWire
IT8 reflection color target
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Internal power supply
AC 230V (50/60 Hz)
Power Consumption Operational (Standby)
45 Watt (6 Watt)
Software Included
Drivers & Utilities, SilverFast Ai 6, EPSON Scan
65.6 cm
45.8 cm
15.8 cm
14.5 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
10 - 80%
Scroll to top
