Click to visit BT.com
BT.com
Wishlist
Epson EH-TW6100 Full HD 3D Home Cinema Projector
Quicklinx: 8L9ZWS00
Mfr#: V11H501040LU
Essential accessories
The EH-TW6100 delivers a 40,000:1 contrast ratio and is enhanced by Epson’s 3LCD technology to provide superb quality images. An equally high White and Colour Light Output of up to 2,300 lumens means you can watch content during the day, without sitting in the dark.
With five different colour modes and an auto-colour optimiser, you can enjoy your content rather than adjusting the menu settings. You can easily align projections with horizontal and vertical keystone correction to ensure a straight and correct image, and also use the split-screen function to watch two sources at the same time.
The front facing ventilation system with low-noise fan means you are not subjected to distracting, uncomfortable hot air while watching content. The two embedded 10W speakers support content, while photos of past holidays and outings can be easily displayed using the slideshow function.
3D content is noticeably bright thanks to Epson’s luminance enhancement technology. A simple press of a button converts 2D high definition films and video games into 3D, so you can experience even more 3D content. Thanks to the 3D depth adjustment function, depth perception and image quality is much more enhanced than previous Epson 3D projectors. Featuring a pair of lightweight, rechargeable Radio Frequency (RF) active shutter 3D glasses, included with the projector, you can enjoy content without interference. You can keep these industry standard glasses for future upgrades, and use them with other home projector and TV manufacturers.
Epson EH-TW6100 LCD projector - 3D
LCD projector - High Definition 1080p
3D Capable
Yes ( 3D glasses included )
Built-in Devices
Stereo speakers
Brightness
2300 lumens
Contrast Ratio
40000:1 (dynamic)
Resolution
1920 x 1080
Native Aspect Ratio
16:9
Bulb type
E-TORL UHE 230 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 5000 hour(s) (economic mode)
Video Input
RGB, composite video, component video ( NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60 )
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
1080p
Speakers
Speaker(s)
AC 120/230 V ( 50/60 Hz )
358 Watt
42 cm x 36.5 cm x 13.7 cm
6 kg
2 years warranty
LCD projector - HD 1080p
3D Capable
Built-in Devices
Stereo speakers
Projector
Brightness
2300 lumens
Contrast Ratio
40000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
0.9 m - 14.5 m
Throw Ratio
1.32 - 2.15:1
Resolution
1920 x 1080
Native Aspect Ratio
16:9
Bulb type
E-TORL UHE 230 Watt
Bulb life cycle
6-segment colour wheel, EPSON Super White, EPSON 3LCD technology, EPSON Cinema Filter, Crystal Clear Fine (C2 Fine), Split Screen, Dynamic Mode, Theater Mode
Lens
Lens Aperture
F/1.51-1.99
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
1080p
Speakers
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
1 x composite video input - RCA , 1 x component video input - RCA x 3 , 2 x HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) ( management ) , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio line-in - RCA x 2 , 1 x 3D glasses - RJ-45 ( management ) , 1 x USB 2.0 - 4 pin mini-USB Type B
3D active glasses charging adapter, wireless remote control
1 x HDMI cable
Security Features
Nominal Voltage
358 Watt
Power Consumption Operational (Standby)
0.35 Watt
42 cm
36.5 cm
13.7 cm
6 kg
2 years warranty
Service & Support Details
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 2000 hours
5 °C
35 °C
Sound Emission
32 dBA
24 dBA
