Click to visit BT.com
BT.com
Wishlist
Epson EH TW6000W - Wireless LCD Projector - 3D Ready - High Definition 1080p - 2200 ANSI lumens
Epson - TW6000
Quicklinx: 7RW1WS00
Mfr#: V11H450041LU
Essential accessories
Wireless Full HD 3D Projector
Bring the power of 3D right to your living room with the Epson EH-TW6000W. Immerse yourself in eye-popping 3D adventures, 2,200 lumens color and white light output, Full HD, 1080p performance and a remarkable contrast ratio of up to 40,000:1. Amazing audio with two powerful built-in 10W stereo speakers. This high-value home theater projector also features great 2D performance. It's never been easier to entertain family and friends with a true-to-life 3D cinematic experience.
Full HD quality images
Watching Hollywood blockbusters, playing the latest video games and cheering on your sports team will be a much more immersive experience thanks to the EH-TW6000W Full HD cinematic projections. The 40,000:1 contrast ratio is enhanced by Epson's 3LCD technology to provide superb quality images and an equally high White and Colour Light Output of up to 2,200 lumens this means you can watch your content during the day, without having to sit in the dark to enjoy it. The auto-colour optimiser chooses a suitable colour mode, depending on the light level in the room, which allows you to concentrate on what you're watching rather than adjusting the menu settings.
Amazingly bright Full HD 3D projections
If you want to take your cinematic experience to the next level, you can easily switch to 3D content at the press of a button. Thanks to Epson's unique luminance enhancement technology, you'll notice immediately that 3D content is much brighter than many Full HD 3D home cinema projectors, delivering 3D images that are comfortable to watch.
Get the most out of your 3D experience
This projector supports a wide range of current 3D sources, ensuring there is a large catalogue of films and programmes available for you to watch so you can make the most of the projector's 3D capabilities.
Wireless connectivity
This projector is also one of the first home projectors to feature wireless Full HD 3D technology. Blu-ray players and laptops can be directly connected with the wireless connection. Alternatively, you can attach your non-wireless devices to a HDMI adapter to enjoy your chosen content without permanent installation or unsightly cables lying around the home.
Easy set-up
This projector is quick and simple to set up, thanks to its manual horizontal slider and automatic vertical keystone correction. Whatever its angle, you can easily align the projection to ensure a straight and correct image, which is great for settling down to watch a film, starting online games quickly or making sure you don't miss the start of important sports events.
User-friendly extras
EH-TW6000W can project two different images simultaneously via its split screen function which is perfect for in-depth multiplayer video gaming or watching two sports events at the same time. The front-facing ventilation system means you are not subjected to uncomfortable hot air while watching the screen and allows you to house the projector in bookcases and other enclosed space.
Epson EH-TW6000W LCD projector - 3D
LCD projector - High Definition 1080p
3D Capable
White
Built-in Devices
Stereo speakers
Brightness
2200 lumens
Brightness (Colour)
2200 lumens
Contrast Ratio
40000:1 (dynamic)
Resolution
1920 x 1080
Native Aspect Ratio
16:9
Bulb type
E-TORL UHE 230 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 5000 hour(s) (economic mode)
Video Input
RGB, composite video, component video
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
1080p
Speakers
Speaker(s)
AC 120/230 V ( 50/60 Hz )
274 Watt
42 cm x 36.5 cm x 13.7 cm
6 kg
2 years warranty
LCD projector - HD 1080p
3D Capable
Built-in Devices
Stereo speakers
Enclosure Colour
White
Projector
Brightness
2200 lumens
Brightness (Colour)
2200 lumens
Contrast Ratio
40000:1 (dynamic)
Image Size
76 cm - 762 cm
Throw Ratio
1.32 - 2.15:1
Resolution
1920 x 1080
Native Aspect Ratio
16:9
Bulb type
E-TORL UHE 230 Watt
Bulb life cycle
EPSON 3LCD technology, Crystal Clear Fine (C2 Fine), Wireless 3D HD function
Lens
Lens Aperture
F/1.51-1.99
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
1080p
Speakers
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
Input Device
External
1 x composite video input - RCA , 1 x component video input - RCA x 3 , 2 x HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) ( management ) , 1 x USB - 4 pin USB Type A , 1 x audio line-in - RCA x 2 , 1 x 3D glasses - RJ-45 ( management )
3D active glasses, WirelessHD Transmitter Set, wireless remote control
1 x HDMI cable
Security Features
Nominal Voltage
274 Watt
Power Consumption Operational (Standby)
0.35 Watt
42 cm
36.5 cm
13.7 cm
6 kg
2 years warranty
Service & Support Details
Limited warranty - 2 years , Limited warranty - lamp - 3 years
Sound Emission
24 dB
