BT.com
Wishlist
Epson EH-TW5300 1920x1080 3LCD HD 3D Home Projector
Delivery
Standard Due date unavailable
Sharp, smooth images for the best looking films and TV
Using Epson's 3LCD technology for exacting brightness and colour, this Full HD projector features high White and Colour Light Output of 2,200 lumens and 35,000:1 dynamic contrast ratio. Together this technology ensures bright, vivid colours and deep blacks. Frame interpolation and Detail Enhancement provide sharper and smoother motion pictures and great detail, for greater clarity, and the EH-TW5300 can also convert standard 2D video into 3D.
Enjoy the big-screen experience with easy set-up
Aimed at people who want a truly big-screen experience at home to watch films, TV and sports, this projector delivers stunning Full HD entertainment at up to 332 inches. Positioning your projector to get a perfectly-aligned image is easy thanks to keystone correction.
Built-in speaker
Though it's primarily designed to be used with a separate sound system, an integrated 5W speaker on the EH-TW5300 makes initial set-up of the projector simple.
Epson EH-TW5300 - LCD projector - portable - 3D
LCD projector - High Definition 1080p
3D Capable
Yes (3D glasses sold separately)
Brightness (White)
2200 lumens
Brightness (Colour)
2200 lumens
Contrast Ratio
35000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
200 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 7500 hour(s) (economic mode)
Video Input
RGB, composite video
Video Modes
1080p
Speakers
Speaker(s) - integrated
291 Watt
29.7 cm x 24.5 cm x 11.4 cm
2.9 kg
2 years warranty
LCD projector - HD 1080p
3D Capable
Projector
Brightness (White)
2200 lumens
Brightness (Colour)
2200 lumens
Brightness (Reduced)
1500 lumens
Contrast Ratio
35000:1 (dynamic)
Image Size
86 cm - 843 cm
Throw Ratio
1.22 - 1.47:1
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
Bulb type
200 Watt
Bulb life cycle
Auto Vertical Keystone, 16:9 aspect ratio support, Split Screen, Dynamic Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.72
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
Video Modes
1080p
Speakers
Integrated
Output Power / Channel
5 Watt
Speakers
1 x mixed channel
1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2
Wireless remote control
Security Features
Power Source
AC
Nominal Voltage
291 Watt
Power Consumption Stand by
0.28 Watt
Software Included
EasyMP Network Projection
29.7 cm
24.5 cm
11.4 cm
2.9 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 3000 hours
35 °C
20 - 80%
Sound Emission
37 dBA
27 dBA
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.62
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.08
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£19.50
£13.60
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.90
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£17.86
C2G USB 2.0 To Fast Ethernet Adapter
Quicklinx: 7BBC | In Stock
£22.72
Scroll to top
