BT.com
Wishlist
Epson EB-Z9750U 7500 Lumens WUXGA LCD Projector - White
Delivery
Standard Due date unavailable
Clear images and 3LCD technology
At 7,500 lumens the EB-Z9750U is bright and boasts a WUXGA resolution. This projector benefits from Epson's 3LCD technology, which ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than competitive projectors .
Perfect for large venues
Museums, auditoriums and corporate environments can benefit from the EB-Z9750U's large projected image, ideal for making a big impact.
Portrait projection
Able to project portrait aspect images, the EB-Z9750U is ideal for digital signage. Welcome to a whole new way of seeing things; portrait mode is also useful when a venue or event, such a fashion show, doesn't lend itself to landscape projection.
Easy set-up
As well as a flexible installation angle and lens shift for off-centre positioning, the EB-Z9750U includes plenty of calibration options such as edge blending, test patterns, frame interpolation and Epson's Super Resolution feature.
The EB-Z9750U includes HDBaseT, which allows up to five connections in one. Optional Wi-Fi is also included for extra flexibility.
Short-throw capability
Great news for auditoriums and lecture theatres; a new and exclusive LU02 short throw lens allows this projector to be positioned closer to the screen.
Epson EB-Z9750U - 3LCD projector - LAN
3LCD projector - High Definition 1080p
Brightness (White)
7500 lumens
Brightness (Colour)
7500 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Bulb type
380 Watt
Bulb life cycle
Up to 2500 hour(s) / up to 4000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video LAN
AC 120/230 V (50 - 60 Hz)
809 Watt
74.1 cm x 53.4 cm x 19.7 cm
25 kg
3LCD projector - HD 1080p
Ethernet
Projector
Brightness (White)
7500 lumens
Brightness (Colour)
7500 lumens
Brightness (Reduced)
6600 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
152 cm - 1270 cm
Projection Distance
2 m - 27.8 m
Throw Ratio
1.57 - 2.56:1
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Bulb type
380 Watt
Bulb life cycle
sRGB colour profile, EPSON 3LCD technology, Crystal Clear Fine (C2 Fine), 16:10 aspect ratio support, DICOM Simulation Mode, Dynamic Mode
Lens
Focus Type
Powered
Zoom Type
Powered
Zoom Factor
1.61x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-60 / +60
Horizontal Keystone Correction
-18 / +18
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video, DVI
1 x DVI-D input - 24+1 pin digital DVI , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input , 1 x USB 2.0 - 4 pin USB Type B , 1 x component video input , 1 x USB - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A , 1 x HDBaseT - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9)
Remote control, HDMI cable clamp
Nominal Voltage
809 Watt
Power Consumption Stand by
0.37 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
74.1 cm
53.4 cm
19.7 cm
25 kg
20 - 80%
Sound Emission
38 dB
35 dB
Scroll to top
