BT.com
Wishlist
Epson EB-Z10000U WUXGA  10000 Lumens LCD Projector - White
Epson EB-Z10000U WUXGA 10000...
£17,802.67
£17,802.67
Add to wishlist
Delivery
Standard Due date unavailable
Clear images and 3LCD technology
At 10,000 lumens the EB-Z10000U is Epson's brightest WUXGA resolution projector yet. This projector benefits from Epson's 3LCD technology, which ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than competitive projectors .
Perfect for large venues
Museums, auditoriums and corporate environments can benefit from the EB-Z10000U's large projected image, ideal for making a big impact.
Portrait projection
Able to project portrait aspect images, the EB-Z10000U is ideal for digital signage. Welcome to a whole new way of seeing things; portrait mode is also useful when a venue or event, such a fashion show, doesn't lend itself to landscape projection.
Easy set-up
As well as a flexible installation angle and lens shift for off-centre positioning, the EB-Z10000U includes plenty of calibration options such as edge blending, test patterns, frame interpolation and Epson's Super Resolution feature.
The EB-Z10000U includes HDBaseT, which allows up to five connections in one. Optional Wi-Fi and SDI are also included for extra flexibility.
Short-throw capability
Great news for auditoriums and lecture theatres; a new and exclusive LU02 short throw lens allows this projector to be positioned closer to the screen.
Epson EB-Z10000U LCD projector
LCD projector - High Definition 1080p
Brightness (White)
10000 lumens
Brightness (Colour)
10000 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens Shift Direction
Horizontal, vertical
Bulb type
380 Watt
Bulb life cycle
Up to 2000 hour(s) / up to 4000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video
1060 Watt
74.1 cm x 53.4 cm x 19.7 cm
26 kg
3 years warranty
LCD projector - HD 1080p
Projector
Brightness (White)
10000 lumens
Brightness (Colour)
10000 lumens
Brightness (Reduced)
6600 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
152.4 cm - 1270 cm
Projection Distance
2 m - 27.8 m
Throw Ratio
1.57 - 2.56:1
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Bulb type
380 Watt
Bulb life cycle
EPSON 3LCD technology, Crystal Clear Fine (C2 Fine), DICOM Simulation Mode, Dynamic Mode, Theater Mode
Lens
Focus Type
Powered
Lens Aperture
F/1.65-2.51
Zoom Type
Powered
Zoom Factor
1.61x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Lens Shift Type
Powered
Vertical Lens Shift
60% / 60%
Horizontal Lens Shift
18% / 18%
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video, DVI, HD-SDI
1 x HDBaseT - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x component video input , 1 x composite video input - BNC x 6 , 1 x S-video input - 4 pin mini-DIN , 1 x HD-SDI , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x HDMI input
Security Features
Nominal Voltage
1060 Watt
Power Consumption Stand by
0.37 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
74.1 cm
53.4 cm
19.7 cm
26 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year / 1000 hours
20 - 80%
Sound Emission
40 dBA
35 dBA
Scroll to top
