BT.com
Wishlist
Epson EB-W12 2800 ANSI Lumens WXGA Projector
Delivery
Standard Due date unavailable
Affordable WXGA business projector
High-quality picture: With an equally high White and Colour Light Output of 2,800 lumens, you can even present in daylight. The WXGA resolution fits your widescreen laptop perfectly and the 3,000:1 contrast ratio ensures sharper detail.
User-friendly: Aligning the picture is quick and easy with automatic vertical keystone correction and an innovative horizontal keystone slider that's unique to Epson. The horizontal keystone slider is an innovative and intuitive new design feature from Epson, making it easy to adjust images to the correct shape when the projector is placed at an angle to the screen. With Epson's 3-in-1 USB Display feature, one cable is all you need for picture, sound and page up/down control. Alternatively, the PC-free function lets you present still photos directly from a USB stick without powering up your computer.
Engaging: Capture the attention of your audience by directly plugging in the optional ELPDC06 USB Visualiser to give a close-up view of documents and 3D objects, eliminating the need for photocopies. The HDMI input lets you display high-definition content, while a built-in 2W speaker ensures audio is delivered with clarity.
Value for money: This affordable projector has many features usually found on more expensive models, so businesses can deliver first-class presentations without breaking the budget. A long lamp life of 5,000 hours* keeps running costs low.
Versatile: The projector is compact and lightweight with a modern design, and offers the flexibility for mobile use. Weighing in at only 2.3kg, it's light enough to carry between meeting rooms with the included carrying bag,
*eco mode
Epson EB-W12 - 3LCD projector
3LCD projector - High Definition 720p
Built-in Devices
Speaker
Brightness
2800 lumens
Brightness (Colour)
2800 lumens
Contrast Ratio
3000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 5000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i
Speakers
Speaker(s) - integrated
AC 240 V
270 Watt
29.5 cm x 22.8 cm x 7.7 cm
2.3 kg
3 years warranty
3LCD projector - HD 720p
Built-in Devices
Speaker
Projector
Brightness
2800 lumens
Brightness (Colour)
2800 lumens
Brightness (Reduced)
2240 lumens
Contrast Ratio
3000:1
Image Size
84 cm - 808 cm
Projection Distance
0.9 m - 10.8 m
Throw Ratio
1.3 - 1.56:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Display Format
1,024,000 pixels (1,280 x 800) x 3
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
EPSON 3LCD technology
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.72
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
Input Device
External
1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A
Carrying case, wireless remote control
1 x VGA cable - 1.8 m
Security Features
Security lock slot (cable lock sold separately), password protection
Nominal Voltage
AC 240 V
270 Watt
Power Consumption Operational (Standby)
0.47 Watt
29.5 cm
22.8 cm
7.7 cm
2.3 kg
Limited warranty - 3 years - on-site , Limited warranty - lamp - 1 year
5 °C
35 °C
Sound Emission
37 dB
29 dB
Scroll to top
