Click to visit BT.com
BT.com
Wishlist
Epson EB-W02 WXGA Projector
Quicklinx: 8308WS00
Mfr#: V11H431141
Standard delivery Delivered within 3-5 working days
Flexible
The projector has a stylish, modern1 design and is compact and lightweight to offer the flexibility of both installation and mobile use. With a short throw distance, producing large screen sizes from a short distance, with a 68-inch screen size from a distance of just 2m. This allows you to make better use of table space, as you no longer need to accommodate the projector in the middle of the table. The direct power on/off feature enables the projector to be activated using a wall switch. When using as a portable projector, the instant-off function means no cool-down time is required, allowing you to pack up and go without delay.
High-quality image
There's no need to use this WXGA projector in the dark as it combines a White and Colour Light Output of 2,600 lumens, 3LCD technology and a 3,000:1 contrast ratio for great picture quality, natural-looking images and excellent brightness. You'll never miss any of the detail either, as the WXGA widescreen resolution (1280x800) will show everything that's on your wide-screen computer without need for adjustments.
Low running costs
A long lamp life of 5,000 hours (in eco mode) helps cut maintenance time and keep running costs low. This projector includes a smaller, brighter, and more efficient E-TORL lamp for clearer and sharper projector images.
Secure
Security is no longer an issue, as a button lock, password lock, Kensington lock, and security bar are in place to protect the projector from unauthorised use. Similarly, company logos can be incorporated into a custom start-up image to replace the standard Epson logo, alerting any unwanted users to the owners' identity, making it clear who the device belongs to.
Epson EB-W02 LCD projector
LCD projector - High Definition
Built-in Devices
Speaker
Brightness
2600 lumens
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 5000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video ( NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60 )
Video Modes
480p, 720p, 1080i, 480i
Speakers
Speaker(s) - integrated
AC 230V
270 Watt
29.5 cm x 22.8 cm x 7.7 cm
2.3 kg
3 years warranty
LCD projector - HD
Built-in Devices
Speaker
Projector
Brightness
2600 lumens
Brightness (Reduced)
2080 lumens
Image Size
84 cm - 805 cm
Projection Distance
0.9 m - 10.8 m
Throw Ratio
1.3 - 1.56:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
OSD Languages
Danish, Hindi, Hebrew, Hungarian, Czech, Croatian, Slovenian, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Catalan, Japanese, Korean, Malay
Auto Vertical Keystone, EPSON 3LCD technology
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.72
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 PIN mini-DIN , 1 x audio line-in - RCA x 2 , 1 x USB - 4 PIN USB Type B
Wireless remote control
1 x VGA cable - 1.8 m
Security Features
Security lock slot (cable lock sold separately), password protection
EMC, IEC 60950-1
Nominal Voltage
AC 230V
270 Watt
Power Consumption Operational ( Standby )
0.47 Watt
29.5 cm
22.8 cm
7.7 cm
2.3 kg
3 years warranty
Service & Support Details
Limited warranty - 3 years , Limited warranty - lamp - 1 year
Sound Emission
37 dB
29 dB
