BT.com
Wishlist
Epson EB-S11 EDU SVGA 3LCD Projector with 3 year lamp warranty edu
Free delivery
Delivery
Standard Due date unavailable
Value for money: This affordable projector has many features usually found on more expensive models, so schools can enhance classroom experiences with high-quality presentations without breaking the budget. It is compact and lightweight with a modern design, and offers the flexibility of both installation and mobile use. The direct power on/off feature enables the projector to be activated without pressing the power button while the tailor-made ELPMB23 optional ceiling mount makes installation quick and simple. A long lamp life of 5,000 hours keeps running costs low.
User-friendly: With Epson's 3-in-1 USB Display feature, one cable is all you need for picture, sound and page up/down control. With the PC-free feature, still photos can be presented directly from a USB stick. Aligning the picture is quick and easy with horizontal and vertical keystone correction buttons.
High-quality: Epson's 3LCD projector engine delivers the natural, accurate colour that's essential for education, so maps, flags and art look true-to-life. With equally high White and Colour Light Output of 2,600 lumens, and 3000:1 contrast ratio, you can achieve a vivid, sharp image.
Engaging: Capture the attention of your class by directly plugging in the optional ELPDC06 USB Visualiser to give a close-up view of 3D objects - perfect for classroom demonstrations.
*eco mode.
Epson EB-S11 LCD projector
LCD projector
Built-in Devices
Speaker
Brightness
2600 lumens
Brightness (Colour)
2600 lumens
Contrast Ratio
3000:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 5000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video
Video Output
RGB
Speakers
Speaker(s) - integrated
270 Watt
22.8 cm x 29.5 cm x 7.7 cm
2.3 kg
3 years warranty
LCD projector
Built-in Devices
Speaker
Projector
Brightness
2600 lumens
Brightness (Colour)
2600 lumens
Brightness (Reduced)
2080 lumens
Contrast Ratio
3000:1
Image Size
76 cm - 889 cm
Throw Ratio
1.45 - 1.96:1
Digital Zoom Factor
1.35x
Resolution
SVGA - SVGA (800 x 600)
Native Aspect Ratio
4:3
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
OSD Languages
Danish, Hindi, Hebrew, Hungarian, Czech, Croatian, Slovenian, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Catalan, Japanese, Korean, Malay
EPSON 3LCD technology
Lens
Focus Type
Manual
Lens Aperture
F/1.44
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
Input Device
External
1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A , 1 x serial RS-232C - 9 pin D-Sub (DB-9) ( management ) , 1 x audio line-in - RCA x 2
Wireless remote control
1 x VGA cable - 1.8 m
270 Watt
Power Consumption Operational (Standby)
0.47 Watt
22.8 cm
29.5 cm
7.7 cm
2.3 kg
Limited warranty - 3 years , Limited warranty - lamp - 3 years
Sound Emission
37 dB
29 dB
Scroll to top
