BT.com
Wishlist
Epson EB-G5900 LCD 5200 Lumens Projector
Delivery
Standard Due date unavailable
First-class picture quality: Audiences will enjoy perfect images, natural colours and brightness of 5,200 lumens white and Colour Light Output, thanks to Epson's 3LCD technology. Deeper blacks are created with the high contrast ratio of 1000:1.
EasyMP Network & Control: Monitor the status of your projector, email the administrator and set up alerts, so the projector emails the administrator in case of any issues.
Split screen: Compare and contrast data such as graphics or worksheets.
Straightforward set-up: Keep installation simple with the centrally positioned lens, while placement options are broadened with the vertical and horizontal lens shift. The bayonet mount and wide 1.8x zoom ratio with the standard lens make positioning the projector a hassle-free process.
Reliable and low maintenance: Product durability is assured while total cost of ownership is kept to a minimum with the C Fine Inorganic LCD panel and long-lasting lamp.
Epson EB-G5900 3LCD projector
3LCD projector
Built-in Devices
Speaker
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g
Brightness
5200 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens Shift Direction
Horizontal, vertical
Bulb type
UHE 330 Watt
Bulb life cycle
Up to 2000 hour(s) / up to 3000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), IEEE 802.11a/g wireless / LAN
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 720i, 526i, 526p
Video Output
RGB
Speakers
Speaker(s) - integrated
442 Watt
47 cm x 38.1 cm x 13.5 cm
6.7 kg
2 years warranty
3LCD projector
Built-in Devices
Speaker
802.11b/g, Ethernet
Projector
Brightness
5200 lumens
Brightness (Reduced)
4160 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 762 cm
Projection Distance
0.8 m - 14.5 m
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHE 330 Watt
Bulb life cycle
OSD Languages
Danish, Hungarian, Czech, Slovenian, Thai, Chinese (traditional), Chinese (simplified), Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Catalan, Japanese, Korean
EPSON 3LCD technology, Crystal Clear Fine (C2 Fine)
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.8x
Keystone Correction Direction
Vertical Keystone Correction
-40 / +40
Horizontal Keystone Correction
-20 / +20
Lens Shift Type
Manual
Vertical Lens Shift
50% / 50%
Horizontal Lens Shift
10% / 10%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11a
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
7 Watt
Speakers
1 x mixed channel
Input Device
External
1 x RGB output - 15 pin HD D-Sub (HD-15) , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 3 x audio line-in - mini-phone 3.5 mm , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone 3.5 mm , 1 x composite video input - BNC , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - BNC x 5
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
442 Watt
Power Consumption Operational (Standby)
0.47 Watt
47 cm
38.1 cm
13.5 cm
6.7 kg
Limited warranty - 2 years , Limited warranty - lamp - 1 year
Sound Emission
38 dB
32 dB
Scroll to top
