Click to visit BT.com
BT.com
Wishlist
Epson EB G5650W Projector
Quicklinx: 7M2HWS00
Mfr#: V11H347040DA
Get a wider picture: See more of the presentation with the WXGA native resolution. Ideal for spreadsheets and data, audiences will see everything as it is displayed on a widescreen computer as this format offers 30% more pixels than XGA.
First-class picture quality: Audiences will enjoy perfect images, natural colours and brightness of 4,500 lumens white and Colour Light Output thanks to Epson's 3LCD technology. And for deeper blacks, experience a high contrast ratio of 2000:1.
Wireless connectivity: Wireless connection (802.11 a/b/g).
EasyMP Network & Control: Monitor the status of your projector, email the administrator and set up alerts, so the projector emails the administrator in case of any issues.  You can also broadcast a message to the network with the included EasyMP Network Projection software.
Split screen: Compare and contrast data such as graphics or worksheets.
Straightforward set-up: Keep installation simple with the centrally positioned lens, while placement options are broadened with the vertical and horizontal lens shift. The bayonet mount and wide 1.8x zoom ratio with the standard lens make positioning the projector a hassle-free process.
Reliable and low maintenance: Product durability is assured while total cost of ownership is kept to a minimum with the C Fine Inorganic LCD panel and long-lasting lamp.
Epson EB-G5650W LCD projector
LCD projector
Built-in Devices
Speaker
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Brightness
4500 lumens
Brightness (Colour)
4500 lumens
Contrast Ratio
2000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
16.7 million colours
Lens
Standard lens
Lens Shift Direction
Horizontal, vertical
Bulb type
UHE 330 Watt
Bulb life cycle
Up to 2000 hour(s) / up to 3000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video IEEE 802.11g/n wireless / LAN
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Output
RGB
Speakers
Speaker(s) - integrated
Microsoft Certification
Compatible with Windows 7
47 cm x 31.2 cm x 13.5 cm
6.8 kg
3 years warranty
LCD projector
Built-in Devices
Speaker
802.11b/g/n , Ethernet
Projector
Brightness
4500 lumens
Brightness (Colour)
4500 lumens
Brightness (Reduced)
3600 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 762 cm
Throw Ratio
1.29 - 2.34:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
UHE 330 Watt
Bulb life cycle
EPSON 3LCD technology
Lens
Standard lens
Focus Type
Manual
Lens Aperture
F/1.65-2.55
Zoom Type
Manual
Zoom Factor
1.8x
Keystone Correction Direction
Vertical Keystone Correction
-40 / +40
Horizontal Keystone Correction
-20 / +20
Lens Shift Type
Manual
Vertical Lens Shift
60% / 60%
Horizontal Lens Shift
10% / 10%
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
7 Watt
Speakers
1 x mixed channel
Input Device
External
1 x RGB output - 15 pin HD D-Sub (HD-15) , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 3 x audio line-in - mini-phone 3.5mm , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone 3.5mm , 1 x composite video input - BNC , 1 x S-video input - 4 PIN mini-DIN , 1 x serial RS-232C - 9 pin D-Sub (DB-9) ( management ) , 1 x network - RJ-45 , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type A , 1 x component video input - BNC x 5
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security label
47 cm
31.2 cm
13.5 cm
6.8 kg
3 years warranty
Service & Support Details
Limited warranty - 3 years , Limited warranty - lamp - 1 year
Sound Emission
38 dB
32 dB
