BT.com
Wishlist
Epson EB-925 3LCD XGA Projector - 3500 ANSI Lumens
Delivery
Standard Due date unavailable
Make presentations more effective
The EB-925 useful features can make presentations more effective. The powerful 16W integrated speaker helps your audience hear clearly, and there's a handy microphone input. Share 3D objects on the big screen by connecting to Epson's ELP-DC06 document camera. You can also share pictures with your audience by projecting directly from your USB drive, camera or portable hard drive using the EasyMP slideshow feature.
Hassle-free installation
Whatever your room layout, installing the EB-925 is straightforward. Even if the projector is at an angle to the screen, you can quickly align the picture using automatic vertical and manual horizontal keystone correction, and the x1.6 optical zoom adds further flexibility. For easy desktop use, the projector's pull-out foot supports a tilt angle of up to 16 degrees.
Easy control and maintenance
Easily control and monitor your projector fleet using Epson's EasyMP advanced networking features. Broadcast image and sound over your network via the LAN input. Save time and hassle by adjusting settings, such as projector on/off times, from a single point on your network. And remove the need for physical checks and free up your IT staff by setting up automatic email alerts for temperature and lamp status.
Wide connectivity
The EB-925 has plenty of connectivity options to suit your needs, including an HDMI input. Connect to your wireless network and present instantly with the optional wireless module and quick wireless connection key. A single USB cable is all that's needed to connect your laptop to the projector thanks to 3-in-1 USB display.
Low TCO
Helping ease demands on your budget, the EB-925 has a low total cost of ownership resulting from its long lamp life of 6,000 hours (in eco mode) and improved dust filter for a longer maintenance cycle of up to 5,000 hours.
Epson EB-925 3LCD projector
3LCD projector
Built-in Devices
Speaker
Brightness
3000 lumens
Brightness (Colour)
3500 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
E-TORL UHE 230 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 6000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video LAN
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
1080p
Video Output
RGB
Speakers
Speaker(s) - integrated
34.5 cm x 26.3 cm x 9.3 cm
3.4 kg
3 years warranty
3LCD projector
Built-in Devices
Speaker
Projector
Brightness
3000 lumens
Brightness (Colour)
3500 lumens
Brightness (Reduced)
2450 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 762 cm
Throw Ratio
1.38 - 2.24:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
E-TORL UHE 230 Watt
Bulb life cycle
EPSON 3LCD technology
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
1080p
LAN and Wireless Image Transferring Protocols
Wired LAN
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
Input Device
External
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 2 x audio line-in - RCA , 1 x USB - 4 pin USB Type B , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x microphone - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
34.5 cm
26.3 cm
9.3 cm
3.4 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year
Sound Emission
37 dB
29 dB
Scroll to top
