BT.com
Wishlist
Epson EB-4850WU WUXGA 3LCD 4000 Lumens Projector
Delivery
Standard Due date unavailable
The EB-4850WU boasts high definition picture quality and a 5,000:1 contrast ratio. This ensures your important presentations are projected in the best possible way.
Thanks to a variety of user-friendly installation features, this projector is easy to set up and use. Its x1.8 wide zoom ratio, as well as manual vertical keystone correction, and arc and point correction, make it quick and easy to set up in a variety of positions without picture blurring or distortion.
With the HDMI input and Display Port, you can connect a variety of high definition devices to play your content effortlessly. In addition, the lamp and filter are easily replaceable which help keep maintenance straightforward, ensuring your projections are as bright and clear as possible.
While presenting, the side-by-side split screen function lets you present from two different sources, such as a separate laptop, for much more in-depth and impressive presentations.
Epson EB-4850WU - 3LCD projector
3LCD projector - High Definition 1080p
Built-in Devices
Speaker
Brightness (White)
4000 lumens
Brightness (Colour)
4000 lumens
Contrast Ratio
5000:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens Shift Direction
Horizontal, vertical
Bulb type
260 Watt
Bulb life cycle
Up to 4000 hours / up to 6000 hours (economic mode)
Video Input
RGB, S-Video, composite video
Speakers
Speaker(s) - integrated
368 Watt
47.2 cm x 35.4 cm x 15.9 cm
6.6 kg
2 years warranty
3LCD projector - HD 1080p
Built-in Devices
Speaker
Projector
Brightness (White)
4000 lumens
Contrast Ratio
5000:1
Image Size
127 cm - 762 cm
Projection Distance
1.4 m - 15 m
Throw Ratio
1.26 - 2.3:1
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Bulb type
260 Watt
Bulb life cycle
sRGB colour profile, EPSON 3LCD technology, 16:10 aspect ratio support
Lens
Focus Type
Manual
Lens Aperture
F/1.65-2.55
Zoom Factor
1.8x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Lens Shift Type
Manual
Vertical Lens Shift
50% / 50%
Horizontal Lens Shift
10% / 10%
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, composite video, S-Video
Speakers
Integrated
Output Power / Channel
10 Watt
1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort , 1 x composite video input - RCA , 1 x component video input - BNC , 1 x S-video input , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm
Wireless remote control
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Nominal Voltage
368 Watt
Power Consumption Stand by
0.39 Watt
Software Included
Drivers & Utilities, EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
47.2 cm
35.4 cm
15.9 cm
6.6 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
20 - 80%
Sound Emission
38 dBA
32 dBA
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
