BT.com
Wishlist
Epson EB-1930 LCD 4200 Lumens Projector
Delivery
Standard Due date unavailable
Convenient use
The Epson EB-1930 combines high-quality output, value-added features and affordability, into a compact and portable projector. It is perfect for corporate or educational use, as it can be easily installed in meeting rooms or used portably from a desktop.
High quality picture
Utilising Epson's 3LCD technology to ensure clearly projected images, the EB-1930 produces vivid, natural colours and an equally high White and Colour Light Output, even in daylight.
The EB-1930 boasts a DisplayPort connector, allowing you to show high definition audio and video content with ease.
Enhanced productivity
Productivity can be greatly increased with a range of features available with the EB-1930, such as Quick Corner.
Epson EB-1930 - 3LCD projector - LAN
3LCD projector
Built-in Devices
Speaker
Ethernet, Fast Ethernet
Brightness
4200 lumens
Contrast Ratio
3000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
215 Watt
Bulb life cycle
Up to 3500 hour(s) / up to 5000 hour(s) (economic mode)
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 720i, 526i, 526p
Video Output
RGB
Speakers
Speaker(s) - integrated
298 Watt
37.7 cm x 10.8 cm x 27.1 cm
3.7 kg
3 years warranty
3LCD projector
Built-in Devices
Speaker
Ethernet
Projector
Brightness
4200 lumens
Contrast Ratio
3000:1
Image Size
76 cm - 762 cm
Throw Ratio
1.38 - 2.24:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Display Format
786,432 pixels (1,024 x 768) x 3
Bulb type
215 Watt
Bulb life cycle
EPSON 3LCD technology
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
Input Device
External
1 x audio line-out - mini-phone stereo 3.5 mm , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9)
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, control panel lock, security bar
Nominal Voltage
298 Watt
Power Consumption Operational (Standby)
0.44 Watt
Software Included
Drivers & Utilities, EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
37.7 cm
10.8 cm
27.1 cm
3.7 kg
Limited warranty - 3 years
5 °C
35 °C
20 - 80%
Sound Emission
37 dB
29 dB
Accessories
£9.99
£7.15
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£19.86
£38.52
£52.15
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£59.19
Scroll to top
