BT.com
Wishlist
Epson EB-1776W LCD 3000 Lumens Projector
Delivery
Standard Due date unavailable
Ultra-mobile, extra-flat: Presenting on the move has never been easier, thanks to the lightweight design. Weighing just 1.7kg, this is the ideal projector for anyone travelling to meetings.
Go wireless: With inclusive high-speed Wi-Fi functionality, setting up a presentation is a smooth, simple process minus the bother of cables.
Enhance your presentation: Once connected, presentations can be controlled and improved with a host of Easy MP features including; 3-in-1 USB display - compatible with Macs as well as PCs, USB plug and play flash drive and multi-screen display where users can connect up to four projectors from a single computer.
Get a wider picture: See more of the presentation with the WXGA resolution. Ideally suited to spreadsheets and data, audiences will see everything displayed on a widescreen computer as this format offers 30% more pixels than XGA.
First-class picture quality: Audiences will enjoy perfect picture quality, impressive natural colours and brightness of 3,000 lumens white and Colour Light Output (CLO), thanks to Epson's 3LCD technology.
Speedy start-up: Simple to set up with features such as quick-start and instant-off.
Straighten up: Slides and images can be aligned and distortion corrected with the projector's automatic vertical and horizontal keystone correction. Projected images fit into any projection screen with a black frame with the Screen Fit function, exclusive to the EB-1776W. And with no placement constraint, you can set up the projector anywhere (not exactly anywhere) in the room and your image will be automatically adjusted to fit the screen.
Epson EB-1776W - 3LCD projector - portable - 802.11g/n wireless
3LCD projector - High Definition
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Brightness
3000 lumens
Brightness (Colour)
3000 lumens
Contrast Ratio
2000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
UHE 230 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 4000 hour(s) (economic mode)
Video Input
RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), IEEE 802.11g/n wireless
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
1080p
Speakers
Speaker(s) - integrated
304 Watt
29.2 cm x 21 cm x 4.4 cm
1.7 kg
3 years warranty
3LCD projector - HD
802.11b/g/n
Projector
Brightness
3000 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 762 cm
Projection Distance
0.7 m - 8.2 m
Throw Ratio
1.04 - 1.26:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
UHE 230 Watt
Bulb life cycle
OSD Languages
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Slovak, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Catalan
EPSON 3LCD technology
Lens
Focus Type
Powered
Lens Aperture
F/1.58-1.7
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
1080p
LAN and Wireless Image Transferring Protocols
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B
Carrying case, USB wireless network adapter, Quick Wireless Connection USB Key, wireless remote control
1 x VGA cable - 1.8 m , 1 x USB cable
Security Features
Security lock slot (cable lock sold separately), password protection
304 Watt
Power Consumption Operational (Standby)
0.4 Watt
29.2 cm
21 cm
4.4 cm
1.7 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
Sound Emission
40 dB
30 dB
Accessories
£9.99
£7.28
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£19.86
£39.09
£52.39
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£59.44
Scroll to top
