BT.com
Wishlist
Epson AcuLaser M2400DT A4 Mono Laser Printer
Delivery
Standard Due date unavailable
Flexible and expandable: The AcuLaser M2400D series has the flexibility to perfectly match the needs of your workgroups and desktop users, with expandable RAM from 32MB up to 320MB. Paper handling is adjustable too, with automatic double-sided printing and a choice of one or two optional additional paper trays to increase capacity to 800 sheets.
Easy compatibility: Seamlessly integrating into most IT environments, the AcuLaser M2400D series supports PCL5e, PCL6, standard ESC/Page, FX, ESCP2, 1239X, Genuine PostScript 3TM and PDF 1.3. It also features a parallel port (D model) or an Ethernet interface (DN model) for easy connectivity.
Lower costs and environmental impact: Your company's cost per page is optimised with a choice of standard and high-capacity toner cartridges. The AcuLaser M2400D series' ENERGY STAR qualified power efficiency and Epson's toner cartridge return programme further reduce bills and minimise environmental impact.
Model configuration:
C11CB47071 Epson AcuLaser M2400D - Main model
C11CB47071BY Epson AcuLaser M2400DT 220v - Main Model + one additional paper tray
C11CB47101 Epson AcuLaser M2400DN - Main model
C11CB47101BY Epson AcuLaser M2400DTN 220v - Main Model + one additional paper tray.
Epson AcuLaser M2400DT - printer - monochrome - laser
Printer Type
Personal printer - laser - monochrome
11.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 35 ppm - monochrome - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
Parallel, USB
300 MHz
RAM Installed (Max)
32 MB (288 MB)
Language Simulation
PCL 5E, PostScript 3, EPSON ESC/P 2, EPSON FX, PCL 6, EPSON ESC/P
Total Media Capacity
550 sheets
Media Handling
50-sheet multipurpose tray, 2x 250-sheet paper cassette
Monthly Duty Cycle (max)
50000 pages
AC 230V
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Server 2008, Apple MacOS X 10.4.11 or later, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
1 year warranty
37.8 cm x 39 cm x 25.5 cm
Printer Type
Printer
Print Speed
Wired
Parallel, USB
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
7 sec
Language Simulation
Media Handling
300 MHz
RAM
RAM Installed (Max)
32 MB / 288 MB (max)
Media Handling
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), F4
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 220 g/m²
550 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) , 2 x automatic - 250 sheets - Legal (216 x 356 mm)
Max Media Capacity
800 sheets
Output Trays Capacity
250 sheets
Duty Cycle
50000 pages
1 x USB 2.0 - 4 pin USB Type B , 1 x parallel - 25 pin D-Sub (DB-25)
Power supply - internal
AC 230V
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
10 °C
32.5 °C
15 - 80%
Sound Emission (Idle)
47 dBA
Sound Emission (Operating)
68 dBA
37.8 cm
39 cm
25.5 cm
11.5 kg
Accessories
Epson AL-MX20 ALM 2400 RETURN TONER CART
Quicklinx: 7YCX | In Stock
£137.91
£120.25
£85.82
Scroll to top
