BT.com
Wishlist
Epson 2500 ANSI Lumens 1920 x 1080\s3LCD Technology Short Throw 6.
Delivery
Standard Due date unavailable
Wireless Full HD pictures
Say goodbye to messy cables. The WirelessHD technology cuts out the need for HDMI cables between the projector and your WiHD devices. Also, Epson's HD transmitter includes five HDMI inputs for maximum versatility.
Sharp and bright images
This Full HD projector uses 3LCD technology and 2,500 lumens brightness with equally high White and Colour Light Output to ensure vivid colours with no rainbow effect, while the 70,000:1 contrast ratio delivers deep blacks and highly detailed images in dark scenes.
Easy positioning
With wide vertical and horizontal lens shift, it's easy to position the EH-TW6600W off-centre to a screen, creating a precisely sized image, with no distortion or stretching. Combined with a 1.6x zoom lens and a compact design, it makes it incredibility simple to set up in any environment. Integrated 20W stereo speakers free you to connect to any external system, while all audio can easily be sent to a sound system using dedicated outputs.
Advanced image technologies
Able to convert 2D video to 3D for maximum versatility, the EH-TW6600W includes seven colour modes – including two especially for 3D – and a pair of RF 3D glasses . By sensing the ambient light, the auto colour optimiser can automatically identify the best setting and Epson's enhanced Super Resolution ensures both 2D and 3D video looks as sharp and crisp as possible.
Epson EH-TW6600W - 3LCD projector - 3D
3LCD projector - High Definition 1080p
3D Capable
Yes (3D glasses included)
Brightness (White)
2500 lumens
Brightness (Colour)
2500 lumens
Contrast Ratio
70000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Lens Shift Direction
Horizontal, vertical
Bulb type
250 Watt
Bulb life cycle
Up to 3500 hours / up to 5000 hours (economic mode)
Video Input
RGB, composite video, component video
Speakers
Speaker(s) - integrated
366 Watt
41 cm x 30.4 cm x 15.7 cm
6.8 kg
2 years warranty
3LCD projector - HD 1080p
3D Capable
Projector
Brightness (White)
2500 lumens
Brightness (Colour)
2500 lumens
Contrast Ratio
70000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
2.9 m - 4.8 m
Throw Ratio
1.32 - 2.15:1
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Bulb type
250 Watt
Bulb life cycle
EPSON 3LCD technology, 16:9 aspect ratio support, Crystal Clear Fine (C2 Fine), Game mode, Dynamic Mode, 480hz 3D drive, 3x Brighter Colors
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Lens Shift Type
Manual
Vertical Lens Shift
60% / 60%
Horizontal Lens Shift
24% / 24%
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, MHL
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
20 Watt
Speakers
2 x right / left channel
1 x composite video input - RCA , 1 x component video input - RCA x 3 , 1 x HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio line-in - RCA x 2 , 1 x USB 2.0 - 4 pin mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A
Wireless remote control
Security Features
Power Source
AC
366 Watt
Power Consumption Stand by
1.8 Watt
41 cm
30.4 cm
15.7 cm
6.8 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 3000 hours
Sound Emission
36 dBA
23 dBA
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.72
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.26
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.20
£14.65
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.90
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.55
C2G USB 2.0 To Fast Ethernet Adapter
Quicklinx: 7BBC | In Stock
£24.46
Scroll to top
